Post by airbraker on Jul 11, 2011 22:01:53 GMT 1
I have just taken my lc250 out for the last 50 miles of running in. It is real nice on slow corners nice and predictable. When I put power on the corners become a twilight zone. The front and back end seem detached and I get strange signals from steering and back end. A bit like one of those shopping trolleys from Asda. The swing arm is fine and everything is nice and tight. I do have Avon ditch finders on would that account for all of it ? They are nice and warm ! I don't remember LC's being so bad. I normally ride a Buell lightning maybe I am just spoiled !
Post by LC_BOTT on Jul 12, 2011 8:22:37 GMT 1
Have you checked the steering head bearings and swingarm bushes, rear shock and tyre pressures etc, can't compare them to a 'modern bike' maybe one of the racers can help with more info?
Post by Norbo on Jul 12, 2011 9:23:15 GMT 1
could be fork oil levels . do the wheels have led on them they may not be ballanced. What knotch is the rear shoker on . tyre presher is very importent on these bikes 28 front 32 back .
Post by airbraker on Jul 12, 2011 11:34:53 GMT 1
Yea forks have'nt been touched since the old king died think they might have ink in them now. Also I havent looked at rear shock setting, what should that setting be ? The bike has just gone through an mot so steering head bearings and stuff should be fine no movement. The bushes in the swing arm are almost new. Did tyre pressure as per manual not sure its 28, 32 wil check that and wheels were balanced. Reckon it might be squishie suspension then ?
Post by Norbo on Jul 12, 2011 11:42:41 GMT 1
Put the rear spring on on its top setting .
If the front wheel is not balanced thats not good . The backs not so bad but the front will realy throw of the handeling if its not done .
Post by airbraker on Jul 14, 2011 23:07:29 GMT 1
Yup that worked a treat rear shock to top setting and tyres up to 28 and 32 !
Post by airbraker on Jul 15, 2011 18:47:47 GMT 1
Used notches on swing arm to adjust chain and align wheel ?
