misfire
Jul 10, 2011 10:01:38 GMT 1
Post by aaronben40 on Jul 10, 2011 10:01:38 GMT 1
So i changed the oil pump and things are slightly better but there is still a slight misfire about the 4k mark under load. On the stand and downhill it revs fine As its only done 50 miles since the rebuild i've not taken it above 6k but it does sometimes feel like it wants to rev higher It seems to be intermittent and i've tried a different coil but no change. Anyone got any suggestions
Post by Norbo on Jul 11, 2011 9:47:45 GMT 1
loos plug caps on teh plugs if not the stator . its a hard one i have sparking problems . are you sure its spark and not carb problems .
