Post by dave1967 on Jul 10, 2011 0:15:57 GMT 1
Bought these brackets from NK and no matter what i do just cant get holes to line up..is this the way they fit..will i have to grind a bit from the middle off bracket or forks??if i put them on back to front holes line up perfectly..has anyone else had this problem..the forks are from LC2 if that helps..starting to get p***ed off with it now. Cheers Dave Attachments:![](//storage.proboards.com/1564063/thumbnailer/t8VGxcgJ97t50N6FHZQS.jpg)
Post by tsa on Jul 10, 2011 7:38:33 GMT 1
If it were mine I would send him this picture and see what he has to say about it.
Post by soccersmyth on Jul 10, 2011 12:02:21 GMT 1
Yes. Contact Nigel first. If it don't fit as it should. Gve him the opportunity to rectify/give advice before introducing the drill/grinder.
jonniebick
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Nice Bike...How fast duz it goo mister????
Post by jonniebick on Jul 10, 2011 13:00:44 GMT 1
looks like you got LC brackets and 31k forks...
Post by dave1967 on Jul 10, 2011 19:08:10 GMT 1
Thing is if i put them on back to front the holes line up perfectly..its the piece in the middle that seems slightly too big..whats different on 40l forks?
jonniebick
Post by jonniebick on Jul 10, 2011 22:51:14 GMT 1
The calliper mounts on 4L0 forks are shorter, without the web in the middle.. All you need to do is remove some of the metal between the lugs on the fork..
Post by Norbo on Jul 11, 2011 8:24:14 GMT 1
Its not often he will make a mistake . He makes all my brackets for me and they have all been spot on except 1 set and he was happy to take them back and re mod them for me so they fitted Percfet .
