Post by stanlc7189 on Jul 5, 2011 23:59:53 GMT 1
Hey guys I've noticed a significant amount of clutch slip when doing rapid gear changes at 8k-9k. I plan to strip the clutch and expect to have to renew the friction plates. I remember on my original LC 30 years ago that I added heavy duty clutch springs at some post-tuning point. I read recently that fitting 3 tz750 springs is an option. Can anyone recommend a solution? Cheers
Post by nikfubar on Jul 6, 2011 0:56:35 GMT 1
Yeah Norbo's heavy duty clutch springs will sort it ![;)](//storage.proboards.com/forum/images/smiley/wink.png) mine was still slipping after replacing the plates untill I fitted these ;D
Post by joyrider on Jul 6, 2011 8:08:14 GMT 1
Yeah Norbo's heavy duty clutch springs will sort it ![;)](//storage.proboards.com/forum/images/smiley/wink.png) mine was still slipping after replacing the plates untill I fitted these ;D I think I will need them then cause I've had this problem since buying my bike and a clutch change. Do you replace all the springs for just some? It gear change harder on your hand?
Post by stanlc7189 on Jul 6, 2011 22:24:53 GMT 1
Thanks for the advice. Six HD clutch springs it is then!
Post by joyrider on Jul 7, 2011 9:08:35 GMT 1
Thanks for the advice. Six HD clutch springs it is then! I think Norbo mentioned to me he only uses 3?
Post by tobster on Jul 7, 2011 10:30:36 GMT 1
I have installed 3 TZ springs from Norbo and the clutch doesn't slip and is not too stiff either. Why are you changing at 8-9k rpm - still another 1-2k rpm to go!!! Oh, and I don't use the clutch on up changes but only on the way down.
Post by nikfubar on Jul 7, 2011 17:53:12 GMT 1
Mine started slipping when I got to about 7.5K at WOT so I changed all 6 springs for Norbo's HD ones & the problem went away ;D the clutch is still light but I have a decent genuine clutch cable & RGV lever & perch
Post by joyrider on Jul 7, 2011 21:52:56 GMT 1
Crazy that Yamaha didn't sort this problem out when it was in production?
Post by lckid on Jul 8, 2011 21:21:38 GMT 1
Crazy that Yamaha didn't sort this problem out when it was in production? They didn't need to the clutches didn't slip when new only when they got worn, ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Post by t4vanman on Jul 9, 2011 19:20:33 GMT 1
I put six h/d springs in mine , never again, 3 sounds good though !!
cooler
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png) ![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Post by cooler on Jul 9, 2011 21:28:23 GMT 1
and atf for your gearbox oil...
Post by Deleted on Jul 10, 2011 8:30:02 GMT 1
when fitting new clutch plates, do you guys bin the big o rings ?
Post by nikfubar on Jul 10, 2011 15:47:38 GMT 1
when fitting new clutch plates, do you guys bin the big o rings ? No, I always fit them, some dont ![:-/](//storage.proboards.com/forum/images/smiley/undecided.png)
higgsy
Post by higgsy on Jul 12, 2011 0:08:38 GMT 1
XS750 EBC friction plates fit and have more surface area, 3 x TZ750 springs and no clutch slip even after repeated race starts. You have to dump the o rings though
howie
![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by howie on Jul 17, 2011 18:44:57 GMT 1
i use 3 HD from norbo and 3 old ones. bought 6 HD ones but the clutch lever felt too stiff so i took it apart again and now use 3 of each. also kept the big rubber rings in as i don't exactly know what they do so thought best not mess with them
Post by lcowner on Jul 17, 2011 18:55:22 GMT 1
anyone tried preloading the springs with a washer? worth a go...........
