Post by weegiboy on Jul 5, 2011 14:47:35 GMT 1
How do all As you know im attempting to build my first ever bike rgv/rd hybrid im using a rgv front and back end so rgv front brake set up , does the rd front brake switch work in this set up or do i have to do some wizardry ? Also im putting a ypvs rear master cylinder to go with the rgv back end which rear brake light switch should i use here , the LC or the YPVS ? All help and advice greatly received. wb :-)
Post by weegiboy on Jul 5, 2011 21:01:42 GMT 1
Nice One RD i think i will buy two new switches from Gandalf (Norbo The All Knowing One :-) ) keep it in the tribe n all that , thanks for steering me in the proper direction , excuse my newbie'ness if i want to put some Karma you're way do i exalt you ? wb :-) ps love the tights anarlergy
Post by jessy03 on Jul 6, 2011 21:52:32 GMT 1
Weegi, as rave says front switch is simple just 2 wires as the rd is, however the rear brake pedal will need modifying if you are using the the YPVS master cylinder, you will also need some spacers.
Post by weegiboy on Jul 7, 2011 14:31:51 GMT 1
Ah Ok will remember tis , thanks wb :-)
