Post by billbott on Jun 30, 2011 22:29:02 GMT 1
Been talking to a mechanic at my local bike shop today, who races R1's. He reckons you are better off fitting a smaller front sprocket, as first gear is very tall (100mph plus!) which I agree with. Trouble is, this will make the speedo read incorrectly. Question: will it say its going faster or slower than it actually is, and also, will it record more, or less mileage?
Post by cb250g5 on Jun 30, 2011 23:47:28 GMT 1
Post by nikfubar on Jul 1, 2011 0:13:37 GMT 1
The R1 speedo sensor is on the output shaft of the gearbox, every time a gear cog passes the hall sensor it induces a voltage, these pulses are what tells the tacco how fast the output shaft is spinning. If you fit a smaller front sprocket, the the rear wheel will turn slower at any given revs compared to the original so the speedo will read slow therefore you will need a speedo healer.
Post by billbott on Jul 1, 2011 7:32:40 GMT 1
The R1 speedo sensor is on the output shaft of the gearbox, every time a gear cog passes the hall sensor it induces a voltage, these pulses are what tells the tacco how fast the output shaft is spinning. If you fit a smaller front sprocket, the the rear wheel will turn slower at any given revs compared to the original so the speedo will read slow therefore you will need a speedo healer. Sounds about right - so this means the mileage recorded will be lower than actual?
