Post by Deleted on Jun 28, 2011 6:22:55 GMT 1
gday, how do you get the old bushes out of the engine damper bars? i pressed the middle bit out but the rubber and outer bit are stuck, will i need to take them to a work shop and get them pressed out or there another trick, thanks again,
Post by Norbo on Jun 28, 2011 9:19:03 GMT 1
Yes a press is the only way
Post by Deleted on Jun 28, 2011 9:59:41 GMT 1
good onya norbo , i suspectected that much after i got a socket head stuck in it from using my vice,i will put you on my karma list when i learn the difference between smite and exalt,
Post by LC_BOTT on Jun 28, 2011 18:16:36 GMT 1
Why don't you just make two cuts with a hacksaw and they will fall out hopefully and save you a few ££'s, don't forget the put the blade through the bushes first
