minime
Post by minime on Jun 26, 2011 23:28:02 GMT 1
Got the pipes back on the 4LO so I thought I would just fire it up before calling it a day Key in, turn, nothing no idiot lights check battery, its low so onto the tender it goes, still nothing Fuses good Then think to myself, side stand switch maybe it has been in the down position for a while Pull it off, squash the pin in and I get the lights but they slowly fade out So now is the switch buggered, can I jump it or do I need a new one? Going to hit it with brake cleaner right now to see if that helps
Post by Norbo on Jun 27, 2011 10:26:22 GMT 1
As above just do the wires bloody things are allways gowing wrong .
minime
Post by minime on Jun 27, 2011 18:01:08 GMT 1
Hit it with some brake cleaner and it is working right now
Think I will jump it out, was just worried that it has something to do with the earth, I know some of my old Kawasaki's were that way
Post by paddyontour on Jul 1, 2011 16:05:24 GMT 1
short it out and dump it ...always were crap from new...who in their correct mind would put a switch right inline with water spraying up around it....doh!!! Couldn't agree more ;D - bad design
minime
Post by minime on Jul 1, 2011 23:25:16 GMT 1
Will jump it out this weekend, got a box of connectors and intend to go through the electrics and eliminate all those insulation taped connections this thing has
