murp
Post by murp on Jun 26, 2011 19:59:03 GMT 1
hi once you have removed all the gubbins from the petrol cap, has anyone any idea how to get the lock barrel out.
cheers
murp
Post by Norbo on Jun 26, 2011 20:13:24 GMT 1
If its the alloy type you just un do the bottom bolts and it all falls out but if its the plastick ones you cant get it all out i think
murp
Post by murp on Jun 26, 2011 21:59:54 GMT 1
it is the alloy type... i undoo the 2 screws on the underside and the cover, 2 alloy plates and the spring come out.... this leaves the lock barrell still secured in the cap... i cant see any way to remove the barrell, allthough it must come out somehow..
cheers all
Post by Bazille on Jun 26, 2011 22:15:04 GMT 1
once all the cover gubbins has been removed you will need to slide a thin screwdriver and push a retaining spring loaded plate (just like the ones the key moves when you insert it into barrel) over which will alllow the barrel to be removed!! cheers Colin
murp
Post by murp on Jun 26, 2011 22:28:16 GMT 1
superb.... thanks for info
murp
murp
Post by murp on Jun 28, 2011 7:59:29 GMT 1
had another look.... does the thin screwdriver go down the key hole to slide the plate, or somewhere else.... still cant get the lock barrel out.
cheers
Post by Bazille on Jun 28, 2011 18:32:12 GMT 1
Hi Firstly clean it out with carb cleaner so you can seebetter then from the bottom you need to slide over the plate(spring loaded like key plates) to allow the barrel to be removed from top of cap!
murp
Post by murp on Jun 28, 2011 21:51:59 GMT 1
thanks again hector...
cheers
