murp
![*](//storage.proboards.com/1564063/images/OArpjc3Z26Vu8ExORmaz.png)
Post by murp on Jun 20, 2011 7:38:02 GMT 1
hi guys
i'm new, be gentle with me.... i've just got a 350lc, and wanted to remove the speedo/ revcounter glass to clean the underside of the glass.... has anyone got any tips for prising up the metal ring.... cant get a screwdriver in there.
cheers
dave
btlc
![*](//storage.proboards.com/forum/images/stars/star_black.png) ![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by btlc on Jun 20, 2011 14:38:46 GMT 1
Just done my own, you can get a screwdriver in the step where the two protrusions are and just get 1mm or 2mm at a time, you must be very patient so not to break the thin plastic ring inside clock or chip the glass, gave mine a polish with nilglass then put back in, i used a press and lay down some rubber sheet then put clock face down on rubber then recrimped again 1mm or 2mm at a time, look as good as new.
Post by johnlc on Jun 20, 2011 14:59:06 GMT 1
Post by bryan on Jun 20, 2011 16:24:26 GMT 1
just changed the speedo on my LC/YPVS to a 140mph one, origonal was screeming like a banshee and the needel was waving like a loon. Fairly easy to do, although getting the trip knob is not that simple as its held on with something like locktight. Once you have the glass off and remover the 2 screws you can get a small pair of needle nose pliers on the thread to hold it or possiblt a small screw driver into the gear to lock it. It wont just unscrew unless its been off b4.
murp
Post by murp on Jun 22, 2011 6:52:11 GMT 1
thanks for the replys.... think i will live with the small marks on the underside of the glass...had a go at prising the metal ring up, but the metal seems too hard, and plastic too soft for guaranteed success... dont want to break them for the sake of a few marks.
murp
