Post by cb900my on Jun 19, 2011 20:24:04 GMT 1
Hi Guys my gear change linkage is completely worn out does the one from a 350lc fit as i cant find any for the 31k it looks the same and as alot of people put power valve motors in lc frames i;m guessing it does fit
Post by drew1967 on Jun 19, 2011 20:33:23 GMT 1
I think where it connects to engine is the same but rest is different so you need one to fit your frame.
Post by fordiebeer on Jun 19, 2011 21:06:17 GMT 1
ive got 1 mate in good nick £10.00
Post by bare on Jun 21, 2011 4:00:56 GMT 1
the long threaded shaft connecting the bits is longer on the Valvie one... just swap it over, it's unlikely to have worn :-)
Post by LC_BOTT on Jun 21, 2011 9:20:15 GMT 1
It's the main shaft/bush thats the big difference, it's longer on an LC so you can't get the circlip and washer on, if you want to file one down, it should fit ok as the shaft diameter is the same, I had the same problem as you, got a mint one of this site, but also had a new LC one (I didn't want to ruin it though) there's loads on fleabay Germany at the moment. But for £10 you can't go wrong
Post by cb900my on Jun 21, 2011 18:11:31 GMT 1
Thanks for all the input guys
Post by cb900my on Jun 25, 2011 16:37:47 GMT 1
Hi Fordibear did you get my PM i'm interested in the linkage if you PM me your number i'l give you a call
