Post by lcowner on Jun 17, 2011 18:14:55 GMT 1
this gear that the kickstrt mechanism drives is very sloppy and loose but the brass bushing doesent look that worn or does the shaft am i missing a part or summit here,any ideas?mine is just held on with a washer and circlip.
Post by 1260dave on Jun 17, 2011 18:22:04 GMT 1
thats how they are, mines the same
Post by 1260dave on Jun 17, 2011 18:23:09 GMT 1
have you stripped ya motor yet
Post by lcowner on Jun 17, 2011 19:33:54 GMT 1
cheers ,yes m8 cases ready for vapor blasting... ,and new crank ;D
paulo
Post by paulo on Jun 17, 2011 22:07:46 GMT 1
Hi m8, there is quite a bit of free play, but there should be a shim fitted either side of the gear .
Post by lcowner on Jun 18, 2011 10:32:33 GMT 1
Hi m8, there is quite a bit of free play, but there should be a shim fitted either side of the gear . its just it seems very slopppy,and me thinks whats the point in having a fancy brass bushing if its not a tight fit...what u mean shim either side m8?has anyone a piccy
paulo
Post by paulo on Jun 18, 2011 20:07:10 GMT 1
Hi m8, should have said shim / washer either side, hope the photo clears things up - mine had one missing that' how i know .
Post by lcowner on Jun 19, 2011 10:04:20 GMT 1
ahhhhhh, thats whats wrong with mine then,ive no shim in mine never did have......thanks for that now anyone got one lying about for me? ?
paulo
Post by paulo on Jun 19, 2011 20:32:29 GMT 1
They are still available from Yamaha m8 as that's where i got mine, that's if no one has a spare going.
Post by lcowner on Jun 19, 2011 23:07:11 GMT 1
cheers m8
