Post by nikfubar on Jun 12, 2011 22:35:22 GMT 1
Need a set of 12 disc bolts for my build NC35 front end. These are M6 X 17mm dome heads, looked on line & most places want around £60.00 for the set of 12 I can get M6 x 17mm stainless steel dome heads from Westfield fastners for 16p each are these sets something special or are they just a rip off. Anyone know
Post by morton01 on Jun 15, 2011 21:23:22 GMT 1
I've got no probs been running standard socket button heads in A4ss on my discs for some time. I did notice that the standard ones are normally partially threaded i.e/ there is an unthreaded portion of fastener just below the head.....the one I fitted are fully threaded, or as far as you can thread behind the bolt head.
Of all the bolts I've come across on discs, don't think any have been hardened - probably just High Tensile
Cheers
Post by johnlc on Jun 15, 2011 22:57:24 GMT 1
From the inox fasteners website
If Stainless isn’t as strong as high tensile steel is it going to be strong enough? This is our MOST faq. Firstly it should be made clear that if for whatever reason you require high tensile (HT) bolts you should use original equipment. Secondly if we believed a bolt was not strong enough for a particular application we would not sell it to you. HT steel is used by factories because it is cheap, convenient and saves assembly time. We ran a motorcycle fitted with standard A2 bolts on discs and fork castings etc which were tested on a daily basis for many months and found no problems whatsoever. Not really a surprise when you consider both the hub and the yokes are low tensile cast alloy - the threads on the fastener are actually stronger than the threads in the material. If you need further reassurance - in the seven years we have been selling stainless we have not had a report of a single failure because the bolt wasn’t strong enough
Post by nikfubar on Jun 16, 2011 0:35:44 GMT 1
Cheers Jon Yeah remember reading that many moons ago forgot about Inox. Anyway scowered the internet for ages & found a company called Race discs & got two lovely sets of stainless steel disc bolts for a tenner. So well happy with that ;D better that the £60.00 pro bolt want for the same thing
Post by widget2k4 on Jun 16, 2011 6:59:37 GMT 1
i only ever use stainless, i even have them in my ktm990 discs and use the bike all the time,never had a problem yet .
Post by lcowner on Jun 19, 2011 10:08:57 GMT 1
i only ever use stainless, i even have them in my ktm990 discs and use the bike all the time,never had a problem yet . +1
Post by johnlc on Jun 19, 2011 11:45:35 GMT 1
Cheers Jon Yeah remember reading that many moons ago forgot about Inox. Anyway scowered the internet for ages & found a company called Race discs & got two lovely sets of stainless steel disc bolts for a tenner. So well happy with that ;D better that the £60.00 pro bolt want for the same thing Was it allen bolts that you got
Post by nikfubar on Jun 19, 2011 13:27:45 GMT 1
Cheers Jon Yeah remember reading that many moons ago forgot about Inox. Anyway scowered the internet for ages & found a company called Race discs & got two lovely sets of stainless steel disc bolts for a tenner. So well happy with that ;D better that the £60.00 pro bolt want for the same thing Was it allen bolts that you got No M8 it was these ;D
Post by johnlc on Jun 19, 2011 18:54:07 GMT 1
Quite tidy looking may invest in some for the nc29 wheels
