Post by scott on Jun 12, 2011 20:09:04 GMT 1
got me benelli tnt shock fitted,50 squid from the bay.same length as lc 250/350 but i've made up a swinger from f2 bottom and lc top loop and made it so the backend is raised slightly.fully adjusable shock. needs the two top bushes knockin out to give you the 12mm bolt hole and the bottom mount was just drilled out from 10mm to 12mm with two 12.5 spacers at swingarm mountin point,gotta be worth a go for 50 notes.
Post by bare on Jun 18, 2011 5:04:49 GMT 1
If you don't mind? Approx weight of the Valvie Swinger 'with' the LC hoop? I've been keen to try it myself but was always put off by the possible weight issue.
Post by lcowner on Jun 18, 2011 10:43:39 GMT 1
very nice scott,ive recently put a sv shock in as it was a more or less straight swap, but that looks the nuts
