Post by chaz1234 on Jun 11, 2011 7:31:16 GMT 1
Hi, I'm looking for help and advice on how to fit a rgv250 vj22 swing arm in a rd350 YPVS.
I've never done this before and I'm looking for as much help and advice as possible.
Do I need the RGV linkages?
What shock should i use....etc?
Any help would be really appreciated.
Thanks Sam
Post by soccersmyth on Jun 11, 2011 10:34:07 GMT 1
There's a link to all you need to know somewhere in the forum. If you good with the old searching, you'll get it.
If not. Somebody will come along soon with the link.
Post by midlifecrisisrd on Jun 11, 2011 10:53:25 GMT 1
Hi, Got 2 done different ways.
1st is done with a kit from NK racing, comes with adapter plates that bolt to the centre stand mounts and you use the rgv shock and linkage. Comes with dog bones and reducer bushes for the pivot bolt. You also need to remove the shims under the end caps of the arm. Costs about £125
2nd one has been done by an engineering shop, uses the ypvs shock and linkages but where the tie bars mount has been reduced in width to match the width of the rgv tie bars and bronze bushed. You need to make new dog bones to right legnth.
First one is easiest as just bolts on ( apart from a little bit of grinding and drilling out of a captive nut ) but you lose the centre stand. No real loss as rgv arm has paddock stand mounts.
