Post by Fingermaus on Jun 9, 2011 23:24:23 GMT 1
I'm wanting to change my very tired standard rear shock for something a bit beefier with a bit more ride height without spending plenty of quids Are there any other Yam models which I might be able to fit second hand. I think I read early fzs Fazer 600 shock fits but can't find the thread.
Cheers
Post by JonW on Jun 9, 2011 23:36:44 GMT 1
Post by Fingermaus on Jun 10, 2011 7:44:54 GMT 1
That's brilliant, thanks Jon.
Post by Norbo on Jun 10, 2011 8:04:16 GMT 1
I habve used a Fazer on in the past and it was a real good mon nothing to chop or weld on the bike just a small mod to the shoker
Post by JonW on Jun 10, 2011 8:17:02 GMT 1
Do you have a link Norbo? Ive never seen any info on the mod on the Fazer shock and it sounds interesting.
The R1 shock also fits, again like the r6 it depends on the year and you need to mod the frame...
Post by Fingermaus on Jun 10, 2011 17:44:45 GMT 1
I habve used a Fazer on in the past and it was a real good mon nothing to chop or weld on the bike just a small mod to the shoker And was it from a 98 to 02 model Norbo? Also was the ride height any different?
Post by willieeckerslike on Jun 10, 2011 21:30:27 GMT 1
It does bring the back end up a smidge, the mod is fairly simple. You will need to remove the bottom mount from the rod on the fz shock, you just unscrew it but make sure you compress the spring before you do it or you will definatley get hurt.
Do the same with the powervalve unit and swap it over.
Job done
W
Post by Fingermaus on Jun 10, 2011 22:18:24 GMT 1
I'm sold then, thats just what I was after.Definately going to go down the Fazer route. Thanks
Post by JonW on Jun 11, 2011 6:27:19 GMT 1
Cool, for a change I might try a Fazer one on my 31k then... 600 or 1000? or are they the same?
Post by markg64 on Jun 11, 2011 7:21:49 GMT 1
ive ordered a 600 one for my 31k as i know it fits. not sure of the 1000 one though ok
Post by willieeckerslike on Jun 11, 2011 8:20:21 GMT 1
Use the 600 shock
W
Post by JonW on Jun 11, 2011 13:30:11 GMT 1
Cool, Cheers lads!
Post by dave1w on Jun 18, 2011 14:02:47 GMT 1
Which model fazer is it?
Post by Fingermaus on Jun 20, 2011 21:01:11 GMT 1
I thought it was the early one mate as no-one said otherwise.
Can anyone put this to bed?Early or late model?
Post by willieeckerslike on Jun 20, 2011 21:34:08 GMT 1
Early one is in mine
Post by Fingermaus on Jun 20, 2011 21:52:20 GMT 1
8-)Ta
