Post by airbraker on Jun 4, 2011 18:13:23 GMT 1
Just about to put oil into gearbox of my re-build. Remeber last time I did this I put fully synthetic in and it caused the clutch to slip under loading. Any advice on this subject ? Know I can get semi-synth but cant seem to find mineral oil. Brands and shops please ?
Post by cb250g5 on Jun 4, 2011 18:34:46 GMT 1
Just about to put oil into gearbox of my re-build. Remeber last time I did this I put fully synthetic in and it caused the clutch to slip under loading. Any advice on this subject ? Know I can get semi-synth but cant seem to find mineral oil. Brands and shops please ? My local car spares place sells loads on hypoid 80 / 90 stuff - that's all you need. Nothing fancy going on in these old gearboxes.
Post by t4vanman on Jun 4, 2011 19:01:28 GMT 1
Hi, i always use the original yamalube gearbox oil , availiable at any yamaha dealer.
Post by airbraker on Jun 4, 2011 20:59:50 GMT 1
So the manual "Haynes book of lies" says sae 10w/30 and 10w/40 ! and hypoid 80/90 transmission fluid recomended. I have found some 10w/40 mineral oil in local motor shop what do you recon ??
Post by bare on Jun 5, 2011 18:38:53 GMT 1
Yamalube 10/40 would not allow the selection of N. GL4 75/85 Gear oil (GL4 means clutch pack Safe:-) Works perfectly. Hypoid Oil is ..unsuitable.. it's for Bevel gears
Post by uncleelsie on Jun 5, 2011 19:30:32 GMT 1
i used silkolene gearbox oil as recomended by my local moto x shop, its got to be better than 10/30 engine oil!!
Post by robin on Jun 13, 2011 13:55:41 GMT 1
Ditto yamalube gearbox Oil, but seems to be the best so far, dont put modern car oils in there, as you deffo have a slipping clutch..
Post by K.B on Jun 14, 2011 19:33:46 GMT 1
I use semi synthetic 10/40 castrol that I use in GSXR and its ok.
