Post by bryan on Jun 2, 2011 1:43:39 GMT 1
Sorting out a 31k engine for Powervalvepete on the other forum, thought you might like to see the results Think Pete got lucky in some way, as he rode the bike home. The rods have atleast 7-8mm of deflection side to side, to the point where the both nearly touch the webs on both sides. The right rod has alot of up and down movement on the pin/big end bearing, the left has a fair amount less but still has too much. Piston was on its way to going out the exhaust port in small bits. Rear skirt was on its way to join the front. Anyone know what make of piston this is. They dont have the small raised part on the rear below the windows so I asume the are air cooled or LC pistons. Barrels came off undamaged, will be measured and hope it will only need a hone and 2 piston kits.
Post by JonW on Jun 2, 2011 2:53:34 GMT 1
WOW! scary.... :/
Post by mellow on Jun 2, 2011 5:54:06 GMT 1
Anyone know what make of piston this is. Knackered! ;D
Post by Norbo on Jun 2, 2011 9:37:17 GMT 1
Nasty . Thats a cheepo Thai piston you would'nt get that with a good jap one .
Post by bryan on Jun 2, 2011 9:59:53 GMT 1
also has 4L0 rods, will check its not a 4L0 crank too.
paulo
Post by paulo on Jun 2, 2011 10:37:50 GMT 1
I've heard that liquid metal stuffs good for sticking things back together and would leave you more money for beer ;D ;D ;D ;D ;D.
Post by Norbo on Jun 2, 2011 10:38:05 GMT 1
iF IT HAS LC RODS THATS NOT GOOD IN AN YPVS AS THE LITTLE ENDS ARE 1MM SMALER SO WOUNT SPACE OUT CORRECT IN YPVS CASINGS SO YOU WILL ETHER GET A LOT OF SIDE TO SIDE PLAY OR IT WILL BE A LC CRAMK AND MAY BE MODED CASINGS
Post by lcowner on Jun 2, 2011 10:39:28 GMT 1
holy f**k!
Post by billy on Jun 2, 2011 11:36:15 GMT 1
That's one properly f***ed up piston haha! I recognize the logo inside the piston but I can't remember what brand it is.
Post by buckshot on Jun 2, 2011 11:39:38 GMT 1
Think its what you may call sh*gged. He's been luck if the barrels are OK.
Dave.
Post by paddyontour on Jun 2, 2011 13:26:52 GMT 1
I want a set of those rings 'cos they seem to be the only thing holding 'all the other bits' together It's amazing to think it got him home too ;D
Post by Norbo on Jun 2, 2011 13:35:53 GMT 1
That's one properly f***ed up piston haha! I recognize the logo inside the piston but I can't remember what brand it is. The brand is "cheepo thai crap" available of E-Bay i think a bit of liqued metal in them cracks and your be fine
Post by 1260dave on Jun 2, 2011 13:38:54 GMT 1
i could put you onto a good alloy welder
Post by bryan on Jun 2, 2011 13:46:08 GMT 1
He did say it wasn't running right though! The place doing the crank have not seen one so bad, the thrust washers were half as thick as they should be.
Post by 1260dave on Jun 2, 2011 14:14:52 GMT 1
i took this out of my lads yamaha aerox last week, amazingly it done 45mph, the air filter fell off and he didn't know
Post by rigga on Jun 3, 2011 16:45:01 GMT 1
Match's the work surface !
Post by lcowner on Sept 14, 2011 15:26:53 GMT 1
Sorting out a 31k engine for Powervalvepete on the other forum, thought you might like to see the results Think Pete got lucky in some way, as he rode the bike home. The rods have atleast 7-8mm of deflection side to side, to the point where the both nearly touch the webs on both sides. The right rod has alot of up and down movement on the pin/big end bearing, the left has a fair amount less but still has too much. Piston was on its way to going out the exhaust port in small bits. Rear skirt was on its way to join the front. Anyone know what make of piston this is. They dont have the small raised part on the rear below the windows so I asume the are air cooled or LC pistons. Barrels came off undamaged, will be measured and hope it will only need a hone and 2 piston kits. thats a KHC piston as norbs says its a thai made piston
Post by stanlc7189 on Sept 14, 2011 22:09:07 GMT 1
Deffo NOT a YPVS piston! It looks just like an original LC(4LO) piston - but probably a cheapo copy. Nasty!!
Post by gazilla on Sept 15, 2011 21:24:05 GMT 1
Lucky he got home ,not so lucky with the rebuild bill.
Post by davey on Sept 20, 2011 19:05:23 GMT 1
cheap mmmmm i though that thai cracks were good
Post by gazilla on Sept 22, 2011 23:23:51 GMT 1
Need to ask Ravedaddy that one. ;-)
