Post by aaronben40 on May 30, 2011 20:53:56 GMT 1
After 2 years and much garage time/heartache/money theres only a brake lever and chain to go before its ready to start my 350 for the first time. Trouble is I've got oil down to the pump but the chuffing bleed screw has rounded off. How should i get the beast up and running for the very first time after a full rebore/rebuild. Do i use premix just in case the pump does not work and if so what ratio oil to fuel?? Been wanting to get the bugger on the road for 2 years and now the hour is close at hand i'm brickin it! Any advice gratefully received. Oh will try take some piccys next weekend and post them up so you can see the beast
Post by johnlc on May 30, 2011 21:05:16 GMT 1
Can you not get a grip of the screw with vice grips or similar ,better to be bled in my opinion
Post by lcowner on May 30, 2011 22:10:24 GMT 1
as johnlc says vice grips.....put a litre fuel in premixed before hand and that will give u time to bleed pump 33:1 ratio
Post by johnlc on May 30, 2011 22:28:01 GMT 1
I push the pulley towards the pump for same effect
