stuboy
Post by stuboy on May 30, 2011 15:39:18 GMT 1
Can anything be rectified internally if the speedo seems to lagg and also read too slow ? It seems to take a while to increase in speed and also seems 10mph too slow.
Post by billbott on May 30, 2011 15:45:18 GMT 1
I think mine reads slow too. I remember mine being miles quicker in 1984!
stuboy
Post by stuboy on May 30, 2011 17:52:53 GMT 1
I remember mine was good at overtaking around blind corners but now it wont at all !! Joking aside do they run on like a clutch sort of mechanism only mine IS SLOW even at low speeds.
Post by bare on Jun 1, 2011 18:29:04 GMT 1
Yama speedos are inaccurate. Even when Brand New if memory serves, although many , now 30 years on are wayyy off. Use a GPS and quantify the read error on your particular Speedo.
Not likely there is a reliable fix either.. yes one can dick a wee bit with the needle spring tension.. If capable.. But it's not a sustained effect. Been there done it twice.. waste 'o time is the easy answer. I've fitted a cheap Bicycle speedo gizmo. Small , unobstrusive .. cheap! and surprisingly easy to read.. choose carefully though, some are better for this than others. Caveat: these only read to 99 so if you choose Kilometers/hour the thing is less capable than if you choose Miles/hour
Post by midlifecrisisrd on Jun 2, 2011 20:53:21 GMT 1
Had this with a ypvs speedo, it seems the lubrication on the pivot dries up up and becomes sticky. WD40 freed mine off.
Post by LC_BOTT on Jun 3, 2011 15:49:38 GMT 1
Do you have to take th espeedo apart or can anything be done with it just out of the housing, both mine have stopped, and don't really want to naff them up if a well aimed drop of oil will free them off somehow (speedo and rev counter) was toying with the idea of a drill left on for hours, until the battery went flat.
Post by flames on Jun 3, 2011 15:55:11 GMT 1
if the clock yr looking at reads in mph....yr looking at the wrong clock.the one that reads rpm's is a much more excitng read.
