stuboy
Post by stuboy on May 29, 2011 23:45:05 GMT 1
Is it possible to get an RD350LC to run sweet through the whole rev range if modded ? I have: 31k carbs Boost Bottle Reed Block Spacers Stage 1 Tune and Microns Is there anyone out there with this setup that runs a sweet as a standard unmodded Elsie or is it a case that Yamaha knew best !! Between 6-7k I recon my mountain bike with a one legged man has more pulling power !! My standard Elsie ran sweetly through the rev range with no splutters.
Post by lcowner on May 30, 2011 0:09:46 GMT 1
lol,i know how u feel m8!!!
stuboy
Post by stuboy on May 30, 2011 15:36:07 GMT 1
Maybe we should start a splutter's and stutter's club. Now i remember why I always beat my mate on his Stan Stevens race tune Elsie 20 odd years ago. He was obviously too bogged down in the splutter band !!
Post by 1260dave on May 30, 2011 18:55:18 GMT 1
Is it possible to get an RD350LC to run sweet through the whole rev range if modded ? I have: 31k carbs Boost Bottle Reed Block Spacers Stage 1 Tune and Microns Is there anyone out there with this setup that runs a sweet as a standard unmodded Elsie or is it a case that Yamaha knew best !! Between 6-7k I recon my mountain bike with a one legged man has more pulling power !! My standard Elsie ran sweetly through the rev range with no splutters. whos been grinding your ports, if a cowboys been at um you might never get the jetting right
Post by lckid on Jun 1, 2011 21:46:08 GMT 1
Is it possible to get an RD350LC to run sweet through the whole rev range if modded ? I have: 31k carbs Boost Bottle Reed Block Spacers Stage 1 Tune and Microns Is there anyone out there with this setup that runs a sweet as a standard unmodded Elsie or is it a case that Yamaha knew best !! Between 6-7k I recon my mountain bike with a one legged man has more pulling power !! My standard Elsie ran sweetly through the rev range with no splutters. Bin the Microns and fit std pipes or Allspeeds.
Post by lcowner on Jun 1, 2011 22:17:04 GMT 1
Is it possible to get an RD350LC to run sweet through the whole rev range if modded ? I have: 31k carbs Boost Bottle Reed Block Spacers Stage 1 Tune and Microns Is there anyone out there with this setup that runs a sweet as a standard unmodded Elsie or is it a case that Yamaha knew best !! Between 6-7k I recon my mountain bike with a one legged man has more pulling power !! My standard Elsie ran sweetly through the rev range with no splutters. Bin the Microns and fit std pipes or Allspeeds. dont b silly boy
stuboy
Post by stuboy on Jun 2, 2011 10:41:56 GMT 1
Ditching the stage one head and barrels as tuning seems to f#ck elsies
Post by Norbo on Jun 2, 2011 10:58:33 GMT 1
What kined of microns do you have are they the removable chrome type .
Post by jessy03 on Jun 2, 2011 18:10:25 GMT 1
Put a valvie lump in, mine runs fine from 1k to 10k not any hesitation at all, even with s/s lomas pipes jess
stuboy
Post by stuboy on Jun 2, 2011 23:42:31 GMT 1
Microns have large chrome removable cans. Put standard airbox on and now got better power to 6k but still dies a death of splutter at 6k. running a lot cooler now and starts better but just wont run into power band. Wish I had some standard pipes so I could bin the microns along with the stage one barrels. Will check needle setting tomorrow.
Post by flames on Jun 3, 2011 16:13:47 GMT 1
are the 31k carbs runnin standard jets and settings? maybe they need changing if they are.have you tried your set up with lc carbs to see how it runs with them? mine had head and barrels skimmed and ran a spacer under the barrels.airbox with holes drilled in lid and funnel removed.allspeeds with std carbs and jets.it pulled from idle well into the red line.
Post by lckid on Jun 3, 2011 21:49:04 GMT 1
Bin the Microns and fit std pipes or Allspeeds. dont b silly boy Microns have never suited Yamahas Allspeeds do
Post by pepsisteve on Jun 7, 2011 12:03:14 GMT 1
mine has foam filters, light tune, 31k carbs, small can allspeads, read spacers, and it is as sweet as a nut! took some getting right but well worth it. 2nd gear 10mph and you can throttle stop it and it just pulls all the way to 10k! love it ;D
