stuboy
Post by stuboy on May 29, 2011 23:29:51 GMT 1
What a plank !!!!! Brought a center stand and a grab rail for my rd350lc which I got blasted and powder coated. The got a stainless fixing pin from Norbo. Went to fit it and bugger me no fixings on frame !!!! Were later models of rd350lc made wih no center stand as there are no signs of any fixings being ground off the frame ?
Post by andygraham on May 30, 2011 1:39:18 GMT 1
Sorry to say they all had centre stands fitted Someone has cut the mounts off yours then There's some on eBay at the mo
Post by lcowner on May 30, 2011 9:19:05 GMT 1
What a plank !!!!! Brought a center stand and a grab rail for my rd350lc which I got blasted and powder coated. The got a stainless fixing pin from Norbo. Went to fit it and bugger me no fixings on frame !!!! Were later models of rd350lc made wih no center stand as there are no signs of any fixings being ground off the frame ? yes m8 they all had centre stands,years ago they wer the first thing to come off a they got in the way when scracthing around towns and cities. would say that prop 60 % of bikes had their stands cut off ;D only thing u can do is grind back the powdercoating neatly and weld on some fixings and then pj1 it over.it wont be seen .well having said that the anoraks will be discusted.or else get it re coated after work but i know wat i be doing
stuboy
Post by stuboy on May 30, 2011 19:41:05 GMT 1
Is the 2 "U" shaped brackets that are welded onto the frame ? If so can they be brought or could someone send me a profile so I can get some made in my factory
