Post by mellow on Dec 30, 2005 14:08:45 GMT 1
Hi, just been to try and get my tapered head bearings matched and the guy said he needs the seat bit coz that has the bearing number on it does n e body know the numbers for the top and bottom race? also have contacted my local shop and they say tapered bearings are crap and they dont stock them or fit them coz they are no better than the standard genuine ones and they dont fit properly i always thought tapered were better. they can get me all the genuine yam bits forĀ£22. so now i dont know wether to get tapered or use the standard ball bearing set up
Post by wiggy on Dec 30, 2005 14:24:04 GMT 1
i use taper bearings in my lc sorry i cant help with the part number though
kc104
its gripped, its sorted...
Post by kc104 on Dec 30, 2005 15:19:34 GMT 1
Pretty sure that all lc's and pv's used the same head bearings cos I've just been checking in a parts catalogue and they all have the same part number. I've got a set of tapered bearings for a pv that I don't need. They're brand new still in their box.....yours for a tenner if your're interested.
Post by mellow on Dec 30, 2005 17:02:14 GMT 1
pm sent
Post by mellow on Dec 30, 2005 19:00:32 GMT 1
yeah thanks fiz..........im sure i had them in me valve wayyyyyyy back in the 80's n me m8s with lc's swear by them to
Post by vinze187 on Dec 30, 2005 19:13:42 GMT 1
Tapers are fair easier to adjust mate, SSY125 is the kit of two bearings if memory if correct, Norbo has them at a very good price to!!
Post by vinze187 on Dec 30, 2005 19:14:30 GMT 1
KC! the bearing you got is one a heck of a lot bigger than the other?
Post by mellow on Dec 30, 2005 19:16:07 GMT 1
the bottom one should have a bigger internal diameter
kc104
Post by kc104 on Dec 30, 2005 19:24:19 GMT 1
Top bearing has a 48mm o/d and 25mm i/d bottom bearing has 48mm o/d and 30mm i/d. Just checked these with my old pv stem and they fit ok.
Post by mellow on Dec 30, 2005 19:32:33 GMT 1
just measured my old ones n they seem to b the ones and they have 25YM and 30YM on the actual bearing which must indicate the inner diameter
Post by vinze187 on Dec 30, 2005 20:29:17 GMT 1
This is where my confusion is!!! My innner race even on its spacer (using RGV forks) is very loose and looks to me as the orignal RGV bottom race would fit which mean my frame as a larger bottom than top! can anybody give me a clue on this? Think my frame is an Brazian F2!
kc104
Post by kc104 on Dec 30, 2005 21:00:50 GMT 1
Mellow is right Vinze, the number ont the inner race is its inner diameter. Does yours have a 30 on it? As far as I know all models used the same size bearings.
Post by vinze187 on Dec 30, 2005 21:15:34 GMT 1
ive got the right pv bearings mate but the tapers which are in the headstock are two different sizes from what i can make out
Post by mellow on Dec 30, 2005 21:54:48 GMT 1
sorry vinze im lost here to i woulda thought the headstock races should b the same size but if its a brazillian one who knows wot they may have done unless..................the headstock has been ovalled u need an expert
Post by vinze187 on Dec 31, 2005 13:28:23 GMT 1
No its not oval it just takes a bigger bottom race, the RGV's do this as standard, small top big bottom bearing, if i hold the standard race in place it only just catches on the cup in the headstock only about 1/3 of the bearing area has contact, hmmmm Norbie!! i need advice
Post by mellow on Dec 31, 2005 13:33:42 GMT 1
where is he when u need him
Post by vinze187 on Dec 31, 2005 13:36:57 GMT 1
spanking a naughty money hehe
Post by mellow on Dec 31, 2005 13:41:54 GMT 1
Post by vinze187 on Dec 31, 2005 13:56:42 GMT 1
oooops lol monkey not money lol
Post by Norbo on Jan 1, 2006 13:12:47 GMT 1
SSY125 is the standard code for all tapers for all LC's ans all YPVS ann many more bikes. One is birrer then the other the outside should be the same and the bottom inner will have a biger hool to go over the bottom of the stem . Standard ones are crap so i dont know what that shop was going on about .
Post by vinze187 on Jan 1, 2006 13:38:08 GMT 1
Just had a chat with a mate who races a brazilian and got a post from the other site (sorry was curios and need to know lol) Apparently these guys have just done their head bearings and confirm it does have a much larger outside diameter on the bottom bearing, just waiting to find out the bearing numbers and will post up once i get them
Post by mellow on Jan 7, 2006 18:17:50 GMT 1
ok dudes...........need a bit of advice regardin these bearings n fitting plz wot is the best way to fit the lower bearing race into the head stock? is it ok to wind it in usin the actual bearing fitted onto the yoke? or does it have to be knocked in/drawn in by another arrangement advice much appreciated ta
Post by vinze187 on Jan 7, 2006 18:36:50 GMT 1
have you got a socket thats the same diameter? Block of wood over the race and tap in gentley, then again thats how we do wheel bearings just wait to somebody else comments to be safe
Post by mellow on Jan 7, 2006 19:12:06 GMT 1
im thinkin big socket.............old seat against new seat big socket against that then draw in with long bolt
Post by mellow on Jan 7, 2006 19:27:53 GMT 1
wot the bottom one its recessed
Post by mellow on Jan 8, 2006 15:08:43 GMT 1
JOB DONE ;D
Post by vinze187 on Jan 8, 2006 15:50:20 GMT 1
nice one!!
