stuboy
Post by stuboy on May 9, 2011 21:57:05 GMT 1
How do I check if my RD350LC has the 31K carbs I was told it has ? If It has should they be jetted as if they were on a YPVS of jetted as the normal carbs for my bike should be ? What is a good starting point for my carb settings it is Stage 1 tuned Has Microns Foam Filters 6mm Reed Block Spacers Boost Bottle (assuming I can get it to seal if not standard link pipe will go back on!!)
Post by oldelsieboy on May 9, 2011 22:32:41 GMT 1
How do I check if my RD350LC has the 31K carbs I was told it has ? If It has should they be jetted as if they were on a YPVS of jetted as the normal carbs for my bike should be ? What is a good starting point for my carb settings it is Stage 1 tuned Has Microns Foam Filters 6mm Reed Block Spacers Boost Bottle (assuming I can get it to seal if not standard link pipe will go back on!!) LC/YPVS carbs have ID marks stamped on the bodies which can be seen in this photo (just above the 2T inlet pipe) They will have 31K-00 (I think) if they are 31K carbs. One carb will also have a vacuum take off for the YPVS fuel system which if fitted to a 4L0 MUST be blanked off. HTH OEB
stuboy
Post by stuboy on May 10, 2011 17:29:47 GMT 1
They are 31k carbs. Where is the pipe that has to be blanked off ? There appears to be two breather pipes on each carb(one half way up and one on the bottom of the bowl).
Post by jessy03 on May 10, 2011 19:44:26 GMT 1
inside of the right hand carb
