matt7
Post by matt7 on Dec 7, 2012 10:21:49 GMT 1
Nice builds Trying to get my post count up constructively ! Love the stance of Yamagamma's with USD fronts, I think one of the old Harris/Rotax seats would work well
matt7
Post by matt7 on Apr 9, 2013 20:06:49 GMT 1
I am in the surrey area but am close to London.Constructing a YAMMAGAMMA from a mk2 rg250 does anyone have one so i can get some ideas of how to make my own. Very keen on knowing what type of alternative wheels,front and rear ends may fit,is it best to leave forks as standard or opt for USD type front ends. Any help would be appreciated people. Was searching for Yamagamma info / pics, and found myself here Have you started building one ?
Post by steeley on Apr 15, 2013 10:42:43 GMT 1
gammaguy21,just had a look in on this thread not had a look for a while.the rear subframe on my yamagamma is an rgv vj22 subframe .i modified it to fit ,cut it shorter on the mounting points .being steel it was easy to do.on the rg frame i had some mounting lugs made and welded on.i will get some pics put on by my mate gordi for you with the seat unit off.
Post by gammaguy21 on Apr 15, 2013 14:37:30 GMT 1
gammaguy21,just had a look in on this thread not had a look for a while.the rear subframe on my yamagamma is an rgv vj22 subframe .i modified it to fit ,cut it shorter on the mounting points .being steel it was easy to do.on the rg frame i had some mounting lugs made and welded on.i will get some pics put on by my mate gordi for you with the seat unit off. Thanks steeley. Much appreciated.
Post by threefiftyr on Jun 18, 2013 22:59:13 GMT 1
Im still in the process of aquiring funds for this project. There are some great looking bikes on this thread.
Post by yamagama on Aug 6, 2013 22:36:10 GMT 1
Hello Cinder when fitting the usd fork bottom yolk did you have to use the change the steering stem from the original rg yolk, i have been told that the rgv one is too short. regards Rich. Hi all - dunno if this helps but I am in the middle (?) of a rg250 MkII with VJ22 front and rear end / vj22 bodywork / 31k engine "project" and yes the bottom yoke V22 stem is 6mm too short, I think it may still be ok, I'm testing at present, but worse case you need a friendly engineering firm to cut & shut 6mm into the stem. I think I may get away with the lack of 6mm, but there ain't much thread there, may be a case of bars in hands and nowt else !
richb
Post by richb on Aug 7, 2013 10:37:03 GMT 1
Hi, have had the steering stem from my RG250 removed and fitted to the RGV bottom yoke. Bearings are the same so when I eventually get going with it the RGV upside downers should fit, may have to do some lock stop alterations but will find out soon. Work done by Nigel Kimber who also converted a FZS600 Fazer to fit my RD500. Real nice workmanship.
