stuboy
Post by stuboy on May 7, 2011 23:40:51 GMT 1
My Rd350LC's Build Stage One Tune 31K Carbs Reed block spacers KN style filters Boost Bottle (leaks due to bieng loose in reed blocks !) Micron Exhausts Outcome idle to 6k pulls very average 6k to 7k very painfull spits , sputters and best way round to downchange 9k Brick Wall To be honest my bog standard LC of 25 years ago would piss its self laughing as it left it behind !! Is this just a jetting problem ? It also seems to run hotter than I remember them running.
Post by willieeckerslike on May 8, 2011 7:16:08 GMT 1
I would lose the k+n filters if they are the type that have the metal ends on them amd replace with foam filters, go uip on the main jets. You want to make sure that you replace the boost bottle as the last thing you need is an air leak whilst you are sorting a jetting issue out I assume the carbs are clean inside and the plugs and battery are all good
Willie
stuboy
Post by stuboy on May 8, 2011 12:08:19 GMT 1
Is the 9k brick wall created by having a stage one tune ? I remember having my old Elsie off the rev counter and the speedo. Even though the power band ended I seem to remember it carried on revving. Also I cant see how having a bigger vacum on the balance pipe can make any differance. The reed block rubbers are good but the boost bottle is slack in them and the clips are slack as the boost bottle does not spread the rubber. How far up the temp gauge should it run ? Can you still get balance pipes as the previous owner lost the original.
Post by willieeckerslike on May 8, 2011 19:16:09 GMT 1
The tune should not stop the bike revving, there are lots of reasons why it will not 'rev out'.
I would look at sorting out the known problens, get a fresh balance pipe, this may be causing an air leak which would cause the bike to run lean and this could stop revs.
Post by jessy03 on May 10, 2011 19:58:57 GMT 1
sounds like you're having fun, if you need a std balance pipe I think I've got a spare you can have, pm me your details
