Post by fatfredfaefife on May 2, 2011 15:26:08 GMT 1
Hi All....I know this was covered a few weeks ago (trying to get to the magic 50), have same problem. Been bleeding the oil pump till the cows come home! Have a look at the video on youtube, are the amount of air bubbles aceptable, also note at the end how much oil I have been bleeding. Thanks for any and all help.
Post by scoobytoo on May 2, 2011 15:32:34 GMT 1
are you opening the oil pump right out ? ie pulling pump cable right out so pump is on full chat ?
chez
Post by chez on May 2, 2011 15:36:42 GMT 1
iam sure you should not be running the bike with the bleed screw out It will be sucking in air at the pump I do mine when its not running . just let it drip oil till there are no air bubbles coming out of the pump
Post by nikfubar on May 2, 2011 15:55:40 GMT 1
The bleed screw should only be out to bleed the feed pipe to the pump with the bike NOT running, once oil comes out replace the screw, with the bike on TICK OVER rotate the wheel with the throttle cable attached to it, to fully open. You will see the oil going down the pipes in little pulses left then right. very soon all air bubbles will dissappear.
All you are doing at the moment is sucking air in through the bleed screw hole.
Post by scoobytoo on May 2, 2011 15:55:51 GMT 1
iam sure you should not be running the bike with the bleed screw out It will be sucking in air at the pump I do mine when its not running . just let it drip oil till there are no air bubbles coming out of the pump As above the bleed screw is to bleed oil ( from 2t tank to pump)when engine is static! once running pull pump cable fully whilst engine on idle or just above to bleed remaining air thru system. (ie in oil line from pump tp carbs)
Post by morton01 on May 2, 2011 15:59:44 GMT 1
As said above, you need to put the bleed screw back in otherwise you are just pulling air into the pump.
I've got black feed lines on mine, that way I don't get paranoid by keep checking the feed lines ;D
Ignore this post....must learn to type faster lol. 2 other people replied while I was typing
Post by lcowner on May 2, 2011 16:07:31 GMT 1
that doesent look right m8 a fair bit of air bubbles there........
Post by lcowner on May 2, 2011 16:09:34 GMT 1
just seen bleed screw out y?
Post by fatfredfaefife on May 2, 2011 17:25:25 GMT 1
Thanks to all who replied........knew it would be me being a muppet somewere alone the line. Will try agin with bleed screw in!
Post by soad1110 on May 2, 2011 21:23:31 GMT 1
Yes, looks as though your trying to bleed both parts at once. Bleed the oil tank to the pump 1st without engine running, then bleed pump to engine with engine running.
Post by fatfredfaefife on May 3, 2011 17:01:01 GMT 1
Thanks for all your help, bled today with bleed screw in .......and pulled my wire. No bubbles
Post by oldelsieboy on May 3, 2011 17:22:03 GMT 1
Thanks for all your help, bled today with bleed screw in .......and pulled my wire. No bubbles Easy when you know how OEB
