Post by acurrell on May 2, 2011 13:06:13 GMT 1
Advice needed
I need to repair the thread on the barrel for an exhaust stud. The thread has already been drilled out once and helicoiled and a new helicoil will not now hold.
Any suggestions about how I can fix this ? Is there an alternative to a helicoil which requires a bigger hole?
manxlc
rd250lc,rd400d ty175 and 90cc powerhouse monkey bike,
Post by manxlc on May 2, 2011 13:54:08 GMT 1
can you not get hole filled with weld,then re-drill and tap out new thread to orig spec?,
Post by aaronben40 on May 2, 2011 18:23:00 GMT 1
I've had that repair done to mine by a guy in Bradford where i live. I can get you the contact details if you want them.
Post by acurrell on May 2, 2011 19:16:53 GMT 1
I live in Wakefield - just next door. If you can give me a contact that would be great.
Thanks
Post by acurrell on May 3, 2011 6:43:50 GMT 1
Great
Will give them a try
Thanks
Post by pepsisteve on May 3, 2011 11:45:01 GMT 1
mine was the same as yours and i just got it re-welded and then drilled and taped it using the flange as a guide.
