Post by 4ce on Apr 30, 2011 12:59:58 GMT 1
Refurbed my Valve (Brazillian) a while ago, all I did to the engine was powder coat barrels head and side casing fit new rings and water pump bearing. After rebuild it would get hot to the point of boiling over. Have fitted 3 new head gaskets (2 genuine) tried another thermostate (used) and run it with no stat, a mates radiator new temp sender(landrover). Have had the cover off water pump and impeller is turning and can`t be stopped by hand. Last time fitted pattern gasket and left to tick over for ages, temp remained normal. took it out for a blast and at about 90 mph it blew the top off the expansion tank and soaked me. Starting to piss me off now. any help or suggestions will be gratefully noted and tried. Nigel.
Post by midlifecrisisrd on Apr 30, 2011 19:13:37 GMT 1
Had the same problem years ago, head just wouldn't seal.
Finally worked by slackening base bolts then tightening head bolts before retightening the base ones.
Best check the head is flat though.
Post by 4ce on Apr 30, 2011 19:33:50 GMT 1
Thanks I`ll give that a try when the new head gasket arrives.
kas
i dont smoke but me microns do
Post by kas on May 2, 2011 21:22:46 GMT 1
hi nige, i'm having the same problem,mine looks like the cooling system is gassing up then throwing the water out the expansion bottle,ive got the head off today and im taking it in to work to be checked in the tool room,i think it needs skimming,il keep you posted,kev
