Post by pepsisteve on Apr 26, 2011 13:41:30 GMT 1
i hear a lot about 375cc conversions on the 4LO but i am struggling to find any info on it, anybody got some info or links?
Post by alibongo on Apr 26, 2011 15:51:07 GMT 1
Wait till Norbo gets back of his jollys this week mate. He has done a 410 conversion (I think its 410) using jet ski pistons if I remember correctly. That should give you the extra cc's you are after.
Post by pepsisteve on Apr 26, 2011 19:50:41 GMT 1
cool, will do mate
Post by winnerevo1 on Apr 28, 2011 17:58:40 GMT 1
The only bit I know of the usual 375cc conversion is the use of DT175 pistons and the need to shorten the barrel (the bottom) by about 5mm.
You can usually tell by the 347cm3 cast at base of the barrel being machined half way through so there isn't much of it left to read.
Post by tsa on Apr 29, 2011 13:00:13 GMT 1
The only bit I know of the usual 375cc conversion is the use of DT175 pistons and the need to shorten the barrel (the bottom) by about 5mm. You can usually tell by the 347cm3 cast at base of the barrel being machined half way through so there isn't much of it left to read. This is the correct info for a 4L0 big bore conversion
Post by bare on Apr 30, 2011 18:52:11 GMT 1
What no one seems to mention is that the 'marginal to begin with' 350LC transfer portings/castings get significantly reduced when one Bodges in a Larger liner.
Bigger Bores with a reduction in transfer capacity ? Now's there's a well thought out 'improvement'
