Post by Shytalk on Mar 19, 2008 19:56:49 GMT 1
Post by vin on Mar 19, 2008 21:34:20 GMT 1
doy
Post by doy on Mar 19, 2008 23:20:49 GMT 1
Would have done me pre rebuild :)Look forward to seeing it done.
Post by mellow on Mar 20, 2008 17:49:32 GMT 1
my god m8 that looked mint b4 i had one of those back in '80 summin first "big"bike i bought after passin test.wonder if its still about nice work m8 n e way
Post by Shytalk on Mar 20, 2008 19:44:19 GMT 1
The problem is that they all look good in photos, up close is different, don't get me wrong it wasn't a heap but there were a few bits, the fairing had had some previous repair work; some that you can see and lots that you can't, I think that most of the panels had been repaired or needed repairing, so I gradually got hold of all the bits I needed - good belly pan and mid sections, the tank had been recently done and looked good although it had some sort of cracking type effect under the lacquer, and with that being recent it made the rest stand out a tad. The engine has had the barrels replaced at some time in its life with 1UA barrels and there was an oil leak from the gear selector. The crankcases have never been split - still got all the original fasteners in place, so I decided to do a proper job, body work off, barrels back to 31K - got a few spare engines to choose from; and if I'm doing the barrels it seemed wise to replace the crank seals whilst the engine is out. I then looked at the frame and it had been sprayed previously and this was cracking everywhere so might as well do that as well, talk about in at the deep end Stripping it down revealed only a couple of issues that would have otherwise gone un-noticed, the block connector for one of the electrics had overheated and fell to pieces when I undid it, that was easy enough to repair, the wiring to the rear indicators had worn down to the wire where the seat had been rubbing against it and a couple of other bullet style connectors snapped off when I tried to undo everything, all repaired now though My aim is to return it to original spec as far as possible. I will leave the engine until last I think. Oh and I'm trying to take lots of pictures as I go along, mainly to assist in reassembling
Post by mellow on Mar 21, 2008 12:05:41 GMT 1
cool.keep the pics comin as u go m8..........we all luv piccys
Post by Shytalk on Mar 23, 2008 20:38:04 GMT 1
Rear master cylinder before, when I took it to bits it was half full of rust debris And after powder coating and new repair kit fitting
Post by scott on Mar 23, 2008 22:20:20 GMT 1
nice job simon
Post by Shytalk on Apr 19, 2008 12:24:58 GMT 1
Post by mellow on Apr 19, 2008 14:44:04 GMT 1
thats lookin well cool now m8 i wish id kept mine now
Post by Shytalk on Apr 30, 2008 12:21:09 GMT 1
Shocker cleaned up nice ;D Rear light assembly ready to go on and in place
Post by mellow on Apr 30, 2008 18:46:20 GMT 1
Post by Norbo on Apr 30, 2008 20:04:36 GMT 1
So your not going to see any of this year on then
doy
Post by doy on May 2, 2008 9:19:11 GMT 1
That's coming on nicely mate
Post by Shytalk on Jun 7, 2008 17:25:37 GMT 1
Post by mellow on Jun 7, 2008 17:52:32 GMT 1
just like new
Post by scott on Jun 7, 2008 19:56:25 GMT 1
wish i had the patience(spelling check )to clean my bits up like that simon ,what ya done ur carbs with?
Post by Shytalk on Jun 8, 2008 10:47:57 GMT 1
wish i had the patience(spelling check )to clean my bits up like that simon ,what ya done ur carbs with? Scott, I had them vapoured, then spent a bit of time washing them out thoroughly making sure all the fine residue was out I'm pleased with the finish.
Post by mellow on Jun 8, 2008 22:11:33 GMT 1
im pleased with the finish to ;D
Post by Norbo on Jun 10, 2008 7:57:04 GMT 1
bloody nice that vapor blasting does give a sooper finish . DOY on hear does it
Post by Shytalk on Sept 30, 2008 12:58:20 GMT 1
Post by Norbo on Sept 30, 2008 14:14:33 GMT 1
looks real nice . Seems a shame to spray over that blasting the barrels look well nice all silver .
Post by Shytalk on Oct 2, 2008 17:32:30 GMT 1
Hi Gary, all sorted now mate, used some bumper spray to finish off the insides as they should have been If its worth doing might as well do it properly hey ;D Any tips anyone for the tank, been stood empty for a while whilst it was away being sprayed, came back with bits of crud in it have removed as much as I can get to - any precautions to take before filling with petrol, was thinking of putting an in-line filter in as well.
Post by mellow on Oct 2, 2008 18:19:35 GMT 1
thats lookin the mutts nuts m8
Post by Shytalk on Sept 16, 2009 19:21:08 GMT 1
After many months, nearly a year now I've done some more............... She lives ;D ;D Had a fiddle with the carbs after a teething problem yesterday, put some fuel in the tank and watched helplessly as it pissed out of the overflow pipe. Stripped the carbs one at a time to find the problem, LH carb was fine, RH carb had a knackered float body seal, which caused the RH carb to fill with fuel then not stop filling - deep joy and fumes / petrol throughout the garage yesterday Anyway, sorted that plus added an in line filter and then put some new plugs in - that itself was a t**t to tighten them up, is there a short style plug socket that people use? Fuel to prime, checked for overflow - non - result, turned on ignition, pulled out choke and kicked it over - after about 20 kicks thought WTF Then looked at the kill switch I wonder - flick, kick and ring a ding ding. Gaz check your voice mail ;D ;D ;D There was me reading about all these people starting their fresh rebuilds, 1 or 2 kicks and it fires up thinking bollocks. Anyway dropped the tickover to 1K ish and let her run till warm, no leaks or mishaps so far, will re torque the head when cold, but it's looking good finally. ;D
Post by Shytalk on Apr 27, 2010 19:09:15 GMT 1
Post by mellow on Apr 27, 2010 19:21:45 GMT 1
cant wait to see this finished...............luv these.................that tanks a bit retro innit ;D
Post by Shytalk on Apr 28, 2010 8:14:47 GMT 1
cant wait to see this finished...............luv these.................that tanks a bit retro innit ;D Yes very retro - but like new inside ;D
Post by Shytalk on Apr 28, 2010 8:16:08 GMT 1
really nice simon.... ;D ;D now when are you gonna join up and get it on the lc club stands.... Gaz, can't see it being good enough for a stand, too many anoracks will pick at it for my liking.
Post by Norbo on Apr 28, 2010 9:30:37 GMT 1
Its not all about them looking green bolt standard for a stank at a show mate so long as its a nice bike . I for 1 get bored at looking at the same bikes all the time as shows. they are nice but yours will be new .
