Post by acurrell on Apr 22, 2011 13:17:13 GMT 1
Follow on from Help - Poorly LC
My 350lc runs on the choke side only. The other side just misfires occasionaly. I have checked the carb bowls and they are the correct way round. I have checked the floats and they are OK
The bike is currently running S+B's with 290 jets, but I have the same problem if I put the airbox back on and run with220 jets.
Any ideas?
Post by flames on Apr 23, 2011 8:34:40 GMT 1
could it be a spark plug breaking down? or coil?
Post by lcowner on Apr 23, 2011 8:53:33 GMT 1
pipe between 2 carbs? could be plug i had same problem a while back?see if ur getting spark with it out or swap it over .............
Post by gazilla on Apr 23, 2011 23:24:10 GMT 1
Check throttle slides right way round ie curve to back end.
Post by flames on Apr 24, 2011 8:50:13 GMT 1
i had exactly the same problem with 1 of my ypvs and i solved it by selling the damn bike. lol,i take it u sold the misfire with the bike,and didnt keep it for your next one?
Post by Tone on Apr 24, 2011 10:48:40 GMT 1
Does the Right hand side come in if you rev it if so could be a blocked pilot jet on that side. If you take the jet out you should just be able to see through it. Also as said try a new set of plugs or try swapping them over to see if the problem changes sides .Tone.
Post by pepsisteve on Apr 24, 2011 20:03:38 GMT 1
have both cylinders got good compression? reeds ok?
