Post by Oliver31 on Apr 20, 2011 15:28:05 GMT 1
my 4lo has just been rebuilt however lights work okay main beam,high beam and rear light. front brake light works.
however rear brake light is not working.
any ideas I can only guess rear brakewiring
Post by carlos on Apr 20, 2011 15:31:08 GMT 1
Sticky plunger thing? Wrongly adjusted?
Post by Pidz on Apr 26, 2011 1:36:27 GMT 1
Pull the wires off the rear brake light switch and touch em together. If the brake light comes on, it's a dodgy switch. Re-connect the switch and use your fingers to pull the switch. If this works, you need to adjust the switch height, if not replace the switch, about a fiver.
Post by Oliver31 on Apr 26, 2011 7:08:19 GMT 1
thanks gents
