m4tt
Post by m4tt on Apr 18, 2011 22:04:50 GMT 1
Have just fired up my 1990 F2 following a light restoration and only one of the exhausts is smoking :roll: indicating that its not getting any 2 stroke in that pot? I have bleed the pump thoroughly - the other side fine. The oil supply pipe at the relevant carb has oil present. Any ideas would be gratefully received.
Post by gazilla on Apr 19, 2011 22:17:57 GMT 1
Is it running on both cylinders ie is the barrel getting hot as this may be the problem.?
Post by Norbo on Apr 20, 2011 7:48:42 GMT 1
you could swop the oil lines over and see if the smoking pipe swops over . Is the non smoking pipe stone cold and the other getting worm . have you riden it or just started it up and reved it at your house . have you looked at the plugs . may be swop the plugs . Yopu have a duff one.
