Post by dave1967 on Apr 17, 2011 22:03:44 GMT 1
Just sent frame off to be powder coated and obviously had to strip everything off..hardest thing to get off was the cup that top bearings fit into..had to break it..ive been told you can do away with those anyway and put different bearings in..could someone shed some light on it..i havent a clue..hope ive explained myself properly.
Cheers
Dave
Post by mellow on Apr 17, 2011 22:17:39 GMT 1
You can fit tapered head bearings if thats what u mean m8
Post by LC'Adam on Apr 17, 2011 22:34:54 GMT 1
Don't they use an inner race (cup) too though mellow? I remember having to use extreme man force when removing tapered races from my CR. ... A cheeky pic cause I can ;D
Post by mellow on Apr 17, 2011 22:53:06 GMT 1
just stick a drift through n knock it out from other end
Post by dave1967 on Apr 17, 2011 23:03:47 GMT 1
Yeah thats it tapered head bearings..does that do away with the cup bit?
Post by nikfubar on Apr 17, 2011 23:57:23 GMT 1
No you will need to fit new taper cups to the head stock
Post by dave1967 on Apr 18, 2011 0:01:15 GMT 1
Do they come with the bearings and whats difference between them and original cups?
Post by LC'Adam on Apr 18, 2011 0:35:35 GMT 1
Post by dave1967 on Apr 18, 2011 1:31:33 GMT 1
I seen the ones on ebay..so the cups come with them then.
Post by nikfubar on Apr 18, 2011 6:50:21 GMT 1
I seen the ones on ebay..so the cups come with them then. Yup
Post by trev1340 on Apr 18, 2011 21:54:21 GMT 1
whats that then ?
Post by dave1967 on Apr 19, 2011 4:38:39 GMT 1
I could do with every tip i can get..mind you hope i wont ever have to remove them..i think it was roller bearings already in there thats probably why cup was so difficult to remove
Post by Pidz on Apr 25, 2011 18:58:01 GMT 1
Most cups I have knocked out from the other end of the stock. But my Brazilian 350R was a pain with the upper cup. It was wider than the stock and could not get behind it to give it a bash. I gave in and left it in. I wasn't going to like some do, grind a slot in the frame to get at it. It felt okay with just one new cup and a new set of caged bearings.
