Post by widget2k4 on Apr 12, 2011 23:10:30 GMT 1
hi everone, i am after some help if anyone has done this mod before and could offer some advise please.
i am putting 31k front end and rear wheel onto my rd250lc, i have had no problems with the front end but i have just started the rear and realised the back brake lever wont go on anywhere. i have a bracket that the master cylinder fits to and the caliper is not a problem just the pedal. did the 31k have a pin that came off the frame for the pedal to go on?
its really got me stumped.
thanks
Post by Norbo on Apr 13, 2011 7:20:33 GMT 1
You need to weld a small bracket on to the back of your brake peddel so it will match up and push the mas cyl up
Post by widget2k4 on Apr 13, 2011 8:22:06 GMT 1
thanks, that explains a lot, i have bean trying to use a ypvs pedal to make it work,not got a standard pedal so off to fleabay to look for one.
thanks again
Post by billy on Apr 13, 2011 11:31:10 GMT 1
You need something like this:
Post by widget2k4 on Apr 13, 2011 21:05:29 GMT 1
cool that helps a lot thanks
Post by oldelsieboy on Apr 13, 2011 22:18:00 GMT 1
You need something like this: ;D ;D ;D OEB
Post by widget2k4 on Apr 24, 2011 0:09:39 GMT 1
where did you mount the fluid reservoir?
Post by robin on May 9, 2011 1:42:12 GMT 1
Resevoir original mounted here....threaded insert into frame But then changed it for this.. bit nicer, needs to be on an angle to clear the bracing on the metmachex I had hell of a job bleeding my brakes tooo!
Post by widget2k4 on May 9, 2011 23:11:22 GMT 1
excellent thanks mate
