lloydh
Post by lloydh on Apr 12, 2011 19:44:48 GMT 1
hi does anyone know why my 350 ypvs wont rev ?? ticks over fine but wont rev ??
Post by johnlc on Apr 12, 2011 20:41:24 GMT 1
Has it just started doing this ?
lloydh
Post by lloydh on Apr 12, 2011 20:45:34 GMT 1
i bought it in bits mate painted frame put it all back in and struggled to get a spark eventually got one so kicked it up it runs a bit lumpy but wont rev at all ??
Post by cb250g5 on Apr 12, 2011 21:46:31 GMT 1
Carb slides in wrong way round?
lloydh
Post by lloydh on Apr 12, 2011 21:49:05 GMT 1
dunno will they go in wrong way thought they had a guide pin
Post by graemestab on Apr 13, 2011 16:14:47 GMT 1
easy to put in wrong way round cut out should face the air box done it myself
lloydh
Post by lloydh on Apr 14, 2011 22:05:54 GMT 1
cut outs away from engine , so it aint that
Post by johnlc on Apr 14, 2011 22:10:14 GMT 1
Does it start easy enough ,what does it do when you open the throttle ,is it when it's moving or at a standstill
lloydh
Post by lloydh on Apr 15, 2011 8:59:53 GMT 1
kicks up first time but will not rev at all wont raise the engine speed at all and if you open the throttle up it just stalls , had the plugs out and they get wet so suspect electrical but which one ?? cdi,rotor or coil
Post by johnlc on Apr 15, 2011 9:02:44 GMT 1
High speed windings in stator are a possibiliy ,do a search on this site or Alek's site for how to check
Post by johnlc on Apr 15, 2011 9:03:36 GMT 1
What model ypvs is it 31k, F2 etc
lloydh
Post by lloydh on Apr 15, 2011 17:51:03 GMT 1
its a 31k first of the fully faired ones but ive took it back to a straight bar / round headlamp one but think its called the rd 350 f
Post by mellow on Apr 15, 2011 20:47:26 GMT 1
F1
lloydh
Post by lloydh on Apr 16, 2011 16:36:24 GMT 1
everything is pointing to cdi so if anyone has one
Post by johnlc on Apr 16, 2011 17:18:32 GMT 1
lloydh
Post by lloydh on Apr 16, 2011 22:52:55 GMT 1
nice one ill have a bash at that after i put the r1 to bed tomorrow cheers mate
Post by mellow on Apr 17, 2011 17:16:30 GMT 1
dont talk to me bout R1's need another bloody battery on mine now
Post by carlos on Apr 17, 2011 17:29:56 GMT 1
dont talk to me bout R1's need another bloody battery on mine now Buy an optimate
Post by mellow on Apr 17, 2011 17:37:33 GMT 1
got an accumate same thing ;D
Post by carlos on Apr 17, 2011 17:44:26 GMT 1
and back to the original question, float height wrong or sticking partially closed? Some other fuel starvation? Blocked main jets?
lloydh
Post by lloydh on Apr 17, 2011 21:36:31 GMT 1
ive tried all the carb thing to no joy mate also sometimes the spark looks weak and others a bit better but it never really looks blinding , ive bought a load of bits today and i got some 1ua carbs with the extra pipe from the float bowl are these any better or not really any difference ?? think ive got another rotor and flywheel sorted so ill just keep trying new bits till the bloody thing is sorted !!! still need a cdi tho lol . oh and i had to get a new battery and an optimate for the r1 last year and its been faultless since bless it
Post by paddyontour on Apr 29, 2011 17:49:47 GMT 1
Had a similar thing happen my F2 when one of the main jets fell out 'cos some goon didn't tighten it up -- wasn't me, honest ;D So... could it be something silly like totaly wrong needles in the carbs?
Post by rigga on Apr 29, 2011 18:20:44 GMT 1
As the frame was painted before re installing the motor.... i guess the earth points are clean ? happened to a cr125 of mine years back
lloydh
Post by lloydh on Apr 30, 2011 22:37:32 GMT 1
yeahhh wacked another 52y 50 cdi on and shes up and running like a dream!!!!!!!!! singing like a baby through them lovely microns might try and source some shorter cans tho make it crackle a bit more well happy cheers guys for the help
Post by t4vanman on May 5, 2011 21:01:06 GMT 1
Hi, if it was the cdi then the bike would'nt even run, i would check the ignition pick ups that's the thing which makes the bike rev.
