Post by twostroker on Apr 7, 2011 18:21:02 GMT 1
ive been looking for info on the net about the standard tyre sizes for my f2 and cant find a definite answer. the reason i ask is my rear tyre is almost bald and my front is only half worn so i brought a part worn rear from a guy on here a few months ago and only just noticed its a ditterent size to the one fitted. the one on the bike is-110-90-18-61h the one i brought part worn is-110-80-18-58h
so idealy i want to know the correct size and my have to bin the part worn and buy a correct size tyre,oh there both bt45's.
Post by flames on Apr 7, 2011 18:32:35 GMT 1
someone will come along with a deffo answer,i cant say for ypvs,but my lc runs a 110/90 on the rear.i wd imagine the pv would be the same.
Post by mellow on Apr 7, 2011 18:40:04 GMT 1
FRONT IS 90/90-18 51H REAR IS 110/80-18 58H Got BT45's on mine
cj
Post by cj on Apr 7, 2011 18:53:29 GMT 1
FRONT IS 90/90-18 51H REAR IS 110/80-18 58H Got BT45's on mine BT45's are brill Mellow do you know if the 1983/4 LC2 uses the same spec tyres as the F2?
Post by twostroker on Apr 7, 2011 19:00:04 GMT 1
FRONT IS 90/90-18 51H REAR IS 110/80-18 58H Got BT45's on mine is this what you have got fitted of the sizes it had from the factory? im just a bit paranoid about fitting a different size tyre and screwing up the handling
Post by mellow on Apr 7, 2011 22:18:52 GMT 1
CJ...............Yes m8.according to manual Stroker. I had the tyres fitted and my F2 is stock and those are the sizes in the manual
Post by Deleted on Apr 7, 2011 22:23:09 GMT 1
Yes, Mellow is correct. If it helps convince you, I have an original owners manual and sales brochures, both quote the same size as Mellow say. Different from standard size tyres don't always screw the handling but do change the feel. I have tried larger tyres but I prefer the responsive feel of standard size.
Post by twostroker on Apr 7, 2011 22:24:08 GMT 1
CJ...............Yes m8.according to manual Stroker. I had the tyres fitted and my F2 is stock and those are the sizes in the manual excellent thanks mellow .so mine must have a incorrect tyre fitted at the moment and it probaly explains why it always felt over geared on standard gearing with the 110-90-18.
Post by mellow on Apr 7, 2011 22:32:06 GMT 1
yeah m8 wrong profiled tyre mine handles ok.....not quite as good as R1 but goes round corners fine ;D
