Post by billymc on Apr 5, 2011 22:43:43 GMT 1
hi all just taken lc out of shead to clean up and noticed small bits of corrosion here and there can anyone tell me are vac bags any good and do you have to remove any rust or corrosion before you store it in one ?
Post by ducatidave on Apr 6, 2011 10:13:30 GMT 1
Should just clean b4 put away and spray with scottoil avoidin dscs n pads n tires Had my rd 5yrs n had no corrosion this way exept disc ov which soon cleanup on ride
Post by LC_BOTT on Apr 6, 2011 16:11:59 GMT 1
Don't you have to keep swapping over, and recharging the dessicant for the vac bags? Not sure how long each will last but a couple of hours in an oven is usually enough. I use a bubble instead, and had no problems so far either, time will tell.
Post by mellow on Apr 6, 2011 16:32:08 GMT 1
i have one.left my F2 in it for about a yr in the shed where it cold in winter n hot in summer Came out as clean as it went in.no furring alloy no rust Ideally it would good to have no rust on bike.As said above bike should be washed and PERFECTLY dry when put in the bag.Dont forget crevices water can lay that you cant get too ie radiator fins You can buy the drysorb sacks or wotever they called seperately and they aint that dear so just buy a new one after a yr or so
Post by midlifecrisisrd on Apr 6, 2011 21:33:03 GMT 1
Definately doing this next winter, Lc2 seems of apart from needing the alloy buffed but the N2 wasn't even finished and it has furry bits. Large patch of the clutch casing paint has fur spots, must have been porous and damp when I painted it.
Post by billymc on Apr 7, 2011 21:56:23 GMT 1
ok thanks for the help will be trying some of the above as nothing worse than seeing your bike starting to corrode when so mutch work has go into restoring it
