shawn
Post by shawn on Apr 4, 2011 13:26:40 GMT 1
hi which paint do you guys use to paint your standard front discs on a 4lo, pj1, bbq or other, and which shade of black- satin, gloss etc.. cheers in advance shawn
Post by lcowner on Apr 4, 2011 13:29:56 GMT 1
welcome m8.any of the above mentioned.i use pj1.satin but wathever floats ur boat...
shawn
Post by shawn on Apr 4, 2011 13:41:47 GMT 1
thanks for the quick reply, i've got some satin pj1, but after reading the can it says the temp should be 20c or 70f, is it this critical, want to spray them today but temperature noway near this temp.
shawn
Post by shawn on Apr 4, 2011 15:35:45 GMT 1
risked it and went ahead and sprayed them, turned out really good, used the mrs hair drier after each coat to dry them, pleased with the result, just got the exhausts to do now!
Post by lcowner on Apr 4, 2011 15:45:42 GMT 1
cool put up a piccy m8
Post by twostroker on Apr 4, 2011 20:18:38 GMT 1
ive used normal solvent base coat and 2k clear lauuer with no problems in the past so i would have thought ant paint as long as the disc is keyed up will be ok
