Post by kiwivini on Mar 31, 2011 22:17:42 GMT 1
rd 250 lc 81'
Revs fine and pulls into powerband although just stops at 7000 rpm, im looking for possible causes.
Carbs all cleaned and standard jetting, air filter, exhausts etc. New plugs mixture seems ok.
Bike was running with too much oil wen i got it so im wondering if i need to clean out the exhausts?
Has anyone used caustic soda? Were these ever restricted?
cheers
Post by flames on Apr 5, 2011 9:06:10 GMT 1
when you say stops @7k,do you mean it just wont rev past this? or duz it stutter n misfire and not pull thro it?
Post by kiwivini on Apr 5, 2011 10:43:10 GMT 1
Doesnt rev past 7K
cj
Post by cj on Apr 5, 2011 12:34:22 GMT 1
Ignition timing OK?
Post by LC'Adam on Apr 5, 2011 15:04:49 GMT 1
Plugs might be shot or could be blocked pipes. But could also be ignition....
Post by 1260dave on Apr 5, 2011 20:53:00 GMT 1
have you got the throttle slides mixed up eg the left in the right
Post by cb250g5 on Apr 5, 2011 22:31:38 GMT 1
Is your rev counter faulty?
Post by midlifecrisisrd on Apr 6, 2011 0:49:46 GMT 1
Is your rev counter faulty? That crossed my mind, didn't think it would be too much in the powerband at 7K Steve.
Post by kiwivini on Apr 6, 2011 16:35:15 GMT 1
Thanks for the ideas and keep them coming.
Spark plugs are new, retried the old ones no difference. Gonna try the casutic soda in the pipes, although cant remove one of the baffles (any ideas?) carb slides should be fine, although surely there identical?? rev counter, never thought on that one how would i check? Timing will have to check that also. Also there a set distance for the pickup to be from the flywheel?
cheers
Post by 1260dave on Apr 6, 2011 18:06:00 GMT 1
carb slides should be fine, although surely there i dentical?? the groves on the side of the slides are different if you've mixed them up by putting the left hand slide in the right hand carb they will be both facing the wrong way. if you can see the dots in the windows to syncronize the carbs they are right. a few peoploe have been caught out by this.
Post by kiwivini on Apr 6, 2011 23:25:37 GMT 1
in that case no carbs fine, thanks for heads up though.
Post by 1260dave on Apr 6, 2011 23:33:16 GMT 1
is the throtle cable adjusted properly
Post by airbraker on Jul 30, 2011 13:56:56 GMT 1
Did you solve it ....... I have a similar problem with my 250lc but it seems intermitant !
