Post by billy on Mar 6, 2011 21:01:05 GMT 1
The time to put it all back together is drawing closer and I'm a bit unsure how all the wires and cables should be routed. Any pics or info to share?
lc king
king of lc's
Post by lc king on Mar 6, 2011 21:24:02 GMT 1
when i put mine back together i lay the loom on the bike and you could see where it had been, personly i dont think there is a right or rong as long as it looks good and it works!!!!!
Post by mellow on Mar 6, 2011 22:43:42 GMT 1
AS JAZZY SAYS..... diagram in the advice section m8. Its all pretty easy.....worst bit is the front end round the fork/headlight area
Post by billy on Mar 7, 2011 18:47:06 GMT 1
when i put mine back together i lay the loom on the bike and you could see where it had been, personly i dont think there is a right or rong as long as it looks good and it works!!!!! Aye I tried that and I'm pretty sure how the main loom should be sitting, but as mellow says it is quite a b**ch at the headlight area. Would be great to see some pics of it. PS: I forgot to mention it but I'm talking about a 125, (mk1) so I guess the wiring diagram and cable routing may be different from the 350LC?
Post by mellow on Mar 7, 2011 20:04:40 GMT 1
there is a 125 one too m8
Post by billy on Mar 8, 2011 0:32:04 GMT 1
there is a 125 one too m8 Can you link it mate? I can't find it.
Post by mellow on Mar 8, 2011 18:03:57 GMT 1
Seems to have dissappeared m8 i've reposted it HERE
Post by billy on Mar 8, 2011 19:53:12 GMT 1
Seems to have dissappeared m8 i've reposted it HERE Thank's mate, very helpful! I see it is for mk2/3 though, but I suppose it's more or less the same deal?
Post by mellow on Mar 8, 2011 19:55:35 GMT 1
yeah m8.if u see one of the pics it has round indicators.pretty much the same though
Post by carlos on Mar 9, 2011 22:16:03 GMT 1
It's a lot easier around the headlight if you've got it right! I used the diagram to get mine right! I couldn't have finished my bike without this forum
Post by billy on Mar 9, 2011 22:41:50 GMT 1
Should the main loom go between the "hole" here?
Post by mellow on Mar 9, 2011 22:50:19 GMT 1
main loom comes over top of rad cover and under the bottom yoke and up in front of it m8
Post by billy on Mar 10, 2011 3:47:08 GMT 1
main loom comes over top of rad cover and under the bottom yoke and up in front of it m8 Hehe, yeah I know but I'm not sure where the loom goes after it comes out from under the bottom yoke? It goes up to the headlight area obviously, but not sure if it should go through the "hole" that I marked on the pic?
Post by mellow on Mar 10, 2011 18:29:39 GMT 1
into the headlight bowl as far as i know.not through any hole in the yoke
