scotty
NEWB
Feb 12, 2011 17:44:42 GMT 1
Post by scotty on Feb 12, 2011 17:44:42 GMT 1
Hi Everyone Firstly you will have to excuse me if i dont know all the correct terminology as this is my first rd/ypvs i have ever bought. so here goes... ive just picked up my bike(yesterday) its a 88 f2 with matching numbers. problem is someone in the past has put a single seat conversion on it (badly) i would like to turn it back into original seat format there seems to be a few lugs/brackets missing form behind and back of the seat catch..... so does anybody know if you can buy frame weld on parts or is it a case of donor frame to take them off? thanks Scotty
NEWB
Feb 12, 2011 17:52:54 GMT 1
Post by lcowner on Feb 12, 2011 17:52:54 GMT 1
welcom scotty,yeah u can either make up brackets yourself that are mssing or buy a scrap frame and cut bits off it.either way do all welding grinding bodging before you powder coat frame. if u have a scrap frame that would prob be easiest or ask on here im sure someone has 1.... cheers lco
scotty
NEWB
Feb 12, 2011 17:53:49 GMT 1
Post by scotty on Feb 12, 2011 17:53:49 GMT 1
Hi this is the image of the bike on ebay some of you may have seen it
scotty
NEWB
Feb 12, 2011 17:58:42 GMT 1
Post by scotty on Feb 12, 2011 17:58:42 GMT 1
thanks lco i wasnt sure about being able to buy the new parts but it was worth a try.
so does anyone have a good rear section of frame !wt? any help would be appreciated
NEWB
Feb 12, 2011 18:43:23 GMT 1
Post by Norbo on Feb 12, 2011 18:43:23 GMT 1
That does look horable at the back end . you need a set of under seat side pannels and a back joint pice . The singkle seat thing will just come of and leave the seat.
have you had a good look to see if anything has been cut of . I think with the pannels you should be ok .
NEWB
Feb 12, 2011 19:10:53 GMT 1
Post by lovelydog on Feb 12, 2011 19:10:53 GMT 1
Ha, well done mate. I was watching this one myself, it was only the intervention from Mrs Lovelydog (reminding me I still owe her money for my boat parts that I'd put on her credit card) that stopped me bidding. I think you've done alright there and hope she turns out to be a beauty. Nothing that a pipe bender and a welder can't sort out. My mate reckons it be put right easily and cheaply. Good luck,enjoy her.
NEWB
Feb 12, 2011 21:44:48 GMT 1
Post by scott on Feb 12, 2011 21:44:48 GMT 1
welcome scotty,great name m8 ;D. i would strip the back end off take some pic's and stick em on here and someone will tell ya if the frames had bits cut off,i've got a frame in me shed so could av a look at it and yes i'm choppin the back end off mine so any bits r ur's if u need em m8. where u from?
scotty
NEWB
Feb 13, 2011 12:24:14 GMT 1
Post by scotty on Feb 13, 2011 12:24:14 GMT 1
thanks for your replies Norbo ive had a good look at the back end and looked at pics online to see if i can see what it supposed to lookbut it hard to see clearly.....but the side panel lugs (underseat) are def missing. the seat cowl has been screwed to a standard seat that has been cut down. Do 1ua panels fit F2? Lovelydog.......soz m8 im she will turn out great thanx Scott cheers m8 will get a photo account and post some pics up cheers Scotty
NEWB
Feb 13, 2011 15:43:45 GMT 1
Post by bubba on Feb 13, 2011 15:43:45 GMT 1
hello scotty and welcome along! good luck with your new powervalve sure you will get her all sorted!
scotty
NEWB
Feb 13, 2011 23:11:18 GMT 1
Post by scotty on Feb 13, 2011 23:11:18 GMT 1
cheers thanx bubba and butchers
NEWB
Feb 14, 2011 9:20:13 GMT 1
Post by Shytalk on Feb 14, 2011 9:20:13 GMT 1
1UA panels will fit fine As for the lugs best take some pictures and post them up, you will have a couple of options, either make your own replacements or get a scrap frame that has them and swap them over.
NEWB
Feb 14, 2011 9:47:08 GMT 1
Post by Deleted on Feb 14, 2011 9:47:08 GMT 1
Hello Scotty and welcome. ive had a good look at the back end and looked at pics online to see if i can see what it supposed to lookbut it hard to see clearly..... This should help.... www.skills.plus.com/manuals/RD350F2.pdf
scotty
NEWB
Feb 14, 2011 18:23:15 GMT 1
Post by scotty on Feb 14, 2011 18:23:15 GMT 1
cheers scruff thats the kinda thing ive been looking for. thanx for the advice shytalk
will try and get some pics up soon
NEWB
Feb 15, 2011 17:48:59 GMT 1
Post by mellow on Feb 15, 2011 17:48:59 GMT 1
i put a pic on ur other post m8.if scot will let u have the rear end off his id just weld that on as i think ur rear light bit has been lifted.have a look in other post
scotty
NEWB
Feb 15, 2011 20:00:10 GMT 1
Post by scotty on Feb 15, 2011 20:00:10 GMT 1
i put a pic on ur other post m8.if scot will let u have the rear end off his id just weld that on as i think ur rear light bit has been lifted.have a look in other post cheers mellow yes taillight and indicators have been raised from what i can gather on frame parts that are missing or wrong 1. the first rear brace as you say home made and not stepped like original(is this to hold mudguard? ) 2. side panel lugs by seat catch 3.rear fender bracket (does this hold the indicators too?) thanks scotty
scotty
NEWB
Feb 15, 2011 20:06:56 GMT 1
Post by scotty on Feb 15, 2011 20:06:56 GMT 1
someone will tell ya if the frames had bits cut off,i've got a frame in me shed so could av a look at it and yes i'm choppin the back end off mine so any bits r ur's if u need em m8. where u from? Hi Scott It looks like that frame backend maybe useful to me What do you want for it? i live in Walsall West mids Where abouts are you? cheers Scotty
NEWB
Feb 15, 2011 20:14:02 GMT 1
Post by watchhislegs on Feb 15, 2011 20:14:02 GMT 1
People who do this kind of butchery should hangs their heads in shame; come on, who did it?
NEWB
Feb 15, 2011 20:56:16 GMT 1
Post by scott on Feb 15, 2011 20:56:16 GMT 1
someone will tell ya if the frames had bits cut off,i've got a frame in me shed so could av a look at it and yes i'm choppin the back end off mine so any bits r ur's if u need em m8. where u from? Hi Scott It looks like that frame backend maybe useful to me What do you want for it? i live in Walsall West mids Where abouts are you? cheers Scotty you can av any parts off the rear subframe scott,and i'm in rushall,walsall,west mids m8
NEWB
Feb 15, 2011 21:25:04 GMT 1
Post by mellow on Feb 15, 2011 21:25:04 GMT 1
cheers mellow yes taillight and indicators have been raised from what i can gather on frame parts that are missing or wrong 1. the first rear brace as you say home made and not stepped like original(is this to hold mudguard? ) 2. side panel lugs by seat catch 3.rear fender bracket (does this hold the indicators too?) thanks scotty The mudguard bolts onto the first section behind seat catches. Then theres another section of mudguard/tool tray that mounts to that and the rear section where the side panels also fix to. The rear bracket is bolted onto back of frame by 4 small bolts and yes the indicators mount to that m8
scotty
NEWB
Feb 15, 2011 22:21:36 GMT 1
Post by scotty on Feb 15, 2011 22:21:36 GMT 1
big cheers to Scott and Mellow Thanx for all the advice I will get there in the end Scooty
