Post by bertiemollie on Jan 16, 2011 20:42:51 GMT 1
Hi All, Once I get the right oil pump fitted how much 2t oil do I need i.e. how many turns on the oil pump cable after it is correctly adjusted? I have a "bolt on" can micron, 10W carb, ledar nozzle, K&N and 210 main (to start with as this is what the ledar instructions say) I think I read somewhere on here that a good starting point is one extra turn per "up jet" size. Is this right? If so I need 5.5 turns i.e. 210 - 155 (jet size) Andrew
Post by bertiemollie on Jan 17, 2011 7:05:03 GMT 1
Don't worry Gaz, I haven't ruined it . The air jet isn't fitted. I'll stick with the nozzles and 210 till I have tried it as this is what ledar recommend. If it doesn't work I can always put the old nozzle back in. Cheers Andrew
Post by bertiemollie on Jan 17, 2011 18:47:38 GMT 1
Here is a snapshot of the Ledar fitting instructions which shows the nozzle is suitable for a 10W also and their recommended jet starting point. I'll keep you all posted on how I get on. If I can get it to run as well as my MK1 did back then I will be well pleased.
