Post by bertiemollie on Jan 14, 2011 16:16:13 GMT 1
Just come to adjust up my oil pump and the pully looks different from the Haynes manual which shows a MK1. It is stamped 3J0 which I think is DT125 / 175 MX. Doesn't have the alignment marks in the right place.
I can pinch the pump off my Mk1 or could I use my 3J0 pump with the right pulley?
Are all 125LC pumps the same i.e. Mk1 & Mk2? Fiche numbers for Mk1 & Mk3 are different.
Thoughts would be appreciated.
Thanks
Andrew
Post by bertiemollie on Jan 14, 2011 21:39:32 GMT 1
Update - I pulled the pump off to swap it for the one off my 10W mk1 and the worm gear is different so it won't fit . At least I know they are significantly different and I will change it. So, side cover will be coming off next week to change the worm gear Andrew
