Post by bigal1 on Feb 21, 2012 14:23:24 GMT 1
looks great your like me have a go at anything ....im in just off to get popcorn keep the pics coming
slot
Post by slot on Feb 21, 2012 20:20:43 GMT 1
That is going to look great matey Is that an old mini i spy in one of the pictures ?? Dave
Post by alext on Feb 21, 2012 23:10:34 GMT 1
aye, thats the other toy... the `61 P.O.S.. here seen entering Brunchen1 on the 'ring. 1961 Austin Mini 7 with 87bhp (then a 25bhp shot of Nitrous on top) - nearest thing you can have to a motorbike but stay dry when it rains!
Post by alext on Feb 25, 2012 19:38:40 GMT 1
well.... I dont have the circlip for the water-pump, but my local (usually hopeless) Yamaha Dealer says they have 5 and are actually open on a Sunday, so off downt here I will go tomorrow. but back to the pictures.....
Post by bubba on Feb 25, 2012 22:15:39 GMT 1
not been on for while the last time i had seen the pics you had just started with it, what a cracking job you have done on it! bet your proud how shes turned out!
Post by alext on Feb 26, 2012 16:59:34 GMT 1
Bloody typical!!
off I go to the yamaha dealer, collect the new circlip (all 40p of it), come home, and whats the first thing I find?? - yup the bloody old circlip - in the box of washers.
I think I need to wear my glassses more......
Post by steview on Feb 28, 2012 22:46:51 GMT 1
Your LC looks great, have you still got the aircooled ? looks very like my old one with the monoshock conversion. Might see you down at the Forth bridges during the summer as i am from falkirk.
Post by alext on Feb 29, 2012 9:53:44 GMT 1
nope the aircooled is gone...
sounds like an LC meetup in Queensferry sometime in the summer then???
would be good to see a few out and about.....
Post by nikfubar on Feb 29, 2012 11:31:10 GMT 1
Post by Deleted on Mar 22, 2012 9:22:19 GMT 1
gday, i noticed on the kick starter side of the picture of your motor is missing the plate the goes from the top case to the bottom case near the deflector plate, the only reason i noticed is cause mines bloody missing, im sure i took it off, are they essential? see ya
Post by alext on Mar 22, 2012 9:53:05 GMT 1
If you mean the oil-pump cover, its just not fitted in that picture as I was having problems with the water-pump, so had it all in pieces.
Finally got the seat recovered, so only a couple of things to do , and Im off for an MOT
Post by Deleted on Mar 22, 2012 10:43:53 GMT 1
the part im talking about is part # 4L0-17471-00, its connects the upper and lower cases and also retains a bearing, it looks like i have to order one from the states,ive spent another hour or so looking ,i can remember making it all shiney and new looking but it has just de-materialised, see ya
Post by alext on Mar 22, 2012 17:22:01 GMT 1
Ah!
you had me in a bit of a panic there....
nope. I did fit that bit - the picture shows the engine before it was finally bolted together - that part wouldnt have gone on then as the cases werent pulled together properly. - I remember that part - mine was half-crusty from lying in the bottom of a box - I cleaned it up a fair bit before fitting it.
off out to the garage tonight to check a wheel and also try to get the seat-mounting lugs off the seat-base so I can finish the seat-cover.
Post by midlifecrisisrd on Mar 22, 2012 18:12:33 GMT 1
nope the aircooled is gone... sounds like an LC meetup in Queensferry sometime in the summer then??? would be good to see a few out and about..... Could make it 3 if you let powervalves in. Steve
Post by alext on Jun 14, 2012 16:46:04 GMT 1
my first ever ride on an LC.....
it works!!!!!
runs like a bag-o-shite - but has stopped pissing water out the headgasket - all gears are present... so now on with the little bits before heading for an mot - it will be on the road this summer
Post by alext on Jul 1, 2012 21:53:54 GMT 1
well, I think I may just be booking an MOT next weekend......... just got a reflector and a mirror to sort out
busaash
never have too many toys
Post by busaash on Jul 2, 2012 18:32:57 GMT 1
looking good that alex
Post by alext on Jul 7, 2012 13:11:24 GMT 1
woo-hoo!!!! it passed!!!
its last MOT ran out in 1987, and now 25 years later, its back on the road!!!
just need it to stop rainig now
Post by alext on Jul 12, 2012 19:14:00 GMT 1
well, took it for a wee ride tonight as it was dry!!! - just a couple of miles round the village and got it dirty riding through a big deep puddle, so had to wash it. its highlighted a couple of things - need to fiddle with the pilots - its wayyyy to rich, clutch is not 100% - it works ok, but is dragging and is really stiff to operate. FZR4003tj forks seem to be sprung and damped about right, the SV650 rear shock seems to be not far off either. something is not quite right with the forks, but I was going to strip them and fit new seals and check the bushes. its really willing - starts to hint at a lot of fun from 5k up, but really need to get a lot more miles on it first. its LOUD - a fair bit more than my aircooled was - think I need to go raid the old-mans stock of fibreglass mat for some packing (theres currently none!!) off fior the next 2 weeks,so should be able to get some more miles on it soon. happy as a pig in shite!!!!
Post by alext on Jul 22, 2012 20:02:33 GMT 1
Well, 29 miles on the motor now..... Clutch fixed by lubing the cable!! Forks may be a bit soft - I need to strip and rebuild them this winter anyway SV shock is deffo firm - may need to back the preload off to minimum fitted bigger pilots and main-jets, and it runs a lot better now - off the next 2 days, so should be able to get it much better soon. Sealed up the header to stub join with plenty of silicone - hopefully the bellypan will stay white now. brakes are taking their time bedding in - may actually just buy new discs as the ones Im using are pretty worn. tomorrow I'l try to get to 100miles if it isnt raining.
Post by alext on Nov 12, 2012 13:07:36 GMT 1
Further update before the winter-layup..
I think I'm nearly done!!
410 miles on the clock now.
The throttle didnt stick open on my in 30 miles in the freezing cold on saturday - there was however an ignition issue at one-point that cleared itself - need to check all the wiring over the next couple of months - it felt like something was shorting to earth.
need to fit the TZ clutch springs as the clutch just lets go as things get interesting at 8.5K.
deffo got a warped front disc - trying to find out which, but the drillings are making it awkward to get a proper runout measurement.
Over the winter I will strip the forks, fit new seals and bushes and oil, and repaint the legs.
need to clean the front calipers - machine or sand off the "triumph" logo from them, and repaint them a nicer colour (cant find a decent gold - so they will end up black)
and thats it!!
roll on next year being sunnier and warmer than this one, as if I am going to the NW200, I WILL be doing it on the LC.
Post by flames on Nov 12, 2012 14:46:59 GMT 1
nice one dude.bike looks fantastic.got 190 miles on mine at mo,once its run in im goin to strip it down n finish it off.want to sort the teething probs before i think about making her look good.
smnasn
Post by smnasn on Nov 12, 2012 14:57:50 GMT 1
Fantastic achievement and very inspirational! I hope I can write a similar post one day!
Post by alext on Nov 12, 2012 16:48:48 GMT 1
best picture so far ... the Ford Frozen-white seems awfully hard to photograph properly
Post by marsbar350 on Nov 12, 2012 16:55:03 GMT 1
nice bike alex ! helmets cool aswell are ya putting any stickers on the belly pan? fancy the NW200 meself on the lc.got any details?
Post by midlifecrisisrd on Nov 12, 2012 18:34:33 GMT 1
I'd check the plates before fitting TZ springs.
Got standard plates and springs in my 385 and only slips a little until the oil is at full temp.
Springs tend to make the clutch heavy, some just fit 3. Strangely I think I have a set of HD springs that I didn't use, could split then with you.
Post by alext on Nov 12, 2012 19:01:16 GMT 1
Ive only got 3 anyway...
the plates are probably worn - they were the best of what came in the box.
I was only going to fit the three springs anyway
wheres the best place to buy plates (bearing in mind Im Scottish and fit the stereo-type for tightness!)
Post by midlifecrisisrd on Nov 13, 2012 9:27:12 GMT 1
Ive only got 3 anyway... the plates are probably worn - they were the best of what came in the box. I was only going to fit the three springs anyway wheres the best place to buy plates (bearing in mind Im Scottish and fit the stereo-type for tightness!) Probably just try the springs first, just don't try and buy a genuine gasket for the cover price is scary. Either that or try norbo/ebay/busters/M and P Steve
Post by alext on Nov 13, 2012 10:48:12 GMT 1
yup, looked at an EBC kit from the US of A, but Norbo's genuine ones are still cheaper, so if I need plates, I'll be purchasing (as usual) from him.
going to fit the springs tomorrow if I get the time.
Post by grunt33 on Nov 14, 2012 11:09:59 GMT 1
Looks great . Love the Matt black pipes
