Post by nikfubar on Jan 2, 2011 15:59:50 GMT 1
Just had to remove the swing arm bearings from my NC35 swinger before it goes for powder coat. Bloody needle rollers tried to knock it out from the back & the needles & cage disintigrated wouldn't budge. Saw somewhere about welding onto the bearing to give you something to hit against. Well that didn't work 3 dremile blades & 2 knackered screwdrivers later got the bugger out
Eyeore
Post by Eyeore on Jan 2, 2011 16:04:43 GMT 1
Did you try heating it?
Post by watchhislegs on Jan 2, 2011 16:16:29 GMT 1
I can't wait until I have to do mine! What have you learnt from this experience?!
Post by nikfubar on Jan 2, 2011 16:55:21 GMT 1
I can't wait until I have to do mine! What have you learnt from this experience?! I learnt that I should have looked a bit harder for the picture Martin has put up showing the nut welded into the needle cage. As the cage is hardened it just snaps off the lip, if I had done it this way it proberbly would have come out
Post by watchhislegs on Jan 2, 2011 19:31:10 GMT 1
When I got my last frame powder coated I just used threaded rod and washers and blocked all the holes up where there were bearings instead of removing them. I cleaned all the grease out of them first though. Rides like a dream now.
Post by midlifecrisisrd on Jan 2, 2011 20:08:47 GMT 1
When I got my last frame powder coated I just used threaded rod and washers and blocked all the holes up where there were bearings instead of removing them. I cleaned all the grease out of them first though. Rides like a dream now. Used this method before but the RGV bearings have rubber oil seals in them that I doubt would take the heat from the oven. Steve.
Post by nikfubar on Jan 2, 2011 20:17:34 GMT 1
When I got my last frame powder coated I just used threaded rod and washers and blocked all the holes up where there were bearings instead of removing them. I cleaned all the grease out of them first though. Rides like a dream now. Yeah same as but on this one I had to grind away part of the bearing stop to allow the bearing slieve to go further into the arm thus got ali swarf in the needle bearing so it's fooked
Post by Norbo on Jan 2, 2011 22:32:53 GMT 1
Well at least you got it out in the end
