Post by andygraham on Dec 12, 2010 13:02:57 GMT 1
have stripped the master cylinder down what state its in anyway cleaned it out.like lumpy gravy inside the glass viewer is gunked up. looks like it will only push out.any advice on how to do it? how is it held in?for when i ts replaced
Post by Trubrit on Dec 12, 2010 13:25:27 GMT 1
Did Mine The Other Day With Some Help From Here, Take The Clip Of The Inside & Just Push It Out All Thats Holding It In Is An O-Ring ....Hope This Helps....
Post by andygraham on Dec 12, 2010 15:41:05 GMT 1
trubrit what does the clip on the inside look llike and how do you flirt it out
Post by Trubrit on Dec 12, 2010 16:11:28 GMT 1
Mine Had A Stainless clip on the inside ...Although mines a 4L1 i guess they are held in the same .....If not im sure some one will chip in and help out ..........
Post by gazilla on Dec 12, 2010 21:10:28 GMT 1
Long nose pliers and a scribber did mine.It was quiet fiddly at first but not to bad in the end.I dont think you can get the new plastic sightglass though.
Post by chippy28 on Dec 12, 2010 22:49:41 GMT 1
I dont think you can get the new plastic sightglass though. Oh yes you can,from Norbo
Post by watchhislegs on Dec 13, 2010 19:05:35 GMT 1
Any tips with what to fix a new glass in there with? I hate throwing stuff away so I'm refurbing mine.
Post by bare on Dec 13, 2010 22:51:26 GMT 1
Mine Had A Stainless clip on the inside ...Although mines a 4L1 i guess they are held in the same .....If not im sure some one will chip in and help out .......... Yess 4lo is identical. As an aside one should Realy! be fitting the 1/2" master to a 350CC 4lo as well. Braking will be significantly improved as result. Proof is in the trying :-)
Post by watchhislegs on Dec 14, 2010 0:02:21 GMT 1
F2 ones do not appear to be held in by anything. The replacement glasses from Norbo are thinner therefore I'm unsure how to make it stay in the hole!
Post by gazilla on Dec 14, 2010 0:04:41 GMT 1
Watchhislegs I was told araldite to fix the replacement glass in but not done myself. Norbo is that the glass or plastic ones??
Post by watchhislegs on Dec 14, 2010 0:07:21 GMT 1
Good thinking, it's just a bit messy; brake fluid is also vicious stuff.
