lckwik
Post by lckwik on Dec 9, 2010 23:40:51 GMT 1
Not loving the look of a 1kt front end on my LC, looks a bit unbalanced. What front end could I easily use fitting the following wish list: 110/17 tyre forks a bit chunkier than an lc but no bigger in diameter than about 40mm flat top yoke to weld risers on reasonably cheap
Post by seanrd on Dec 10, 2010 0:08:12 GMT 1
Im using kr1s forks on my LC, twin disc, fat top yoke, rwu and 17 inch front wheel
Post by martinj on Dec 10, 2010 8:26:58 GMT 1
That is one pretty looking LC, well done mate.
Post by midlifecrisisrd on Dec 10, 2010 10:32:02 GMT 1
Know it's on a ypvs but RGV VJ21 front end. 17 inch wheel, simply a 5 mm spacer ( from norbo ) and rew eld stops on bottom yoke to fit. Top yoke is not flat but risers are easily machined before welding. Steve
lckwik
Post by lckwik on Dec 10, 2010 19:26:25 GMT 1
I have always liked the look of suzook discs as they remind me of my old 1100k so I have picked up a set of bandit 400 yokes with bar clamps, one fork and twin disc front wheel for £40 due to the fella losing the fork leg. Must say the KR1 wheels look sweet though!!!!
Post by cb250g5 on Dec 11, 2010 12:39:44 GMT 1
Im using kr1s forks on my LC, twin disc, fat top yoke, rwu and 17 inch front wheel Sean - what rear are you going to use. As you know I'm KR1s both ends, but the 140/60/18 rear tyre is in short supply & I don't think I can get a 150 in the JMC. I fancy a 17" replacement, but the 5 spoke kwak ones are funny to match. Suggestions welcome.
Post by oldelsieboy on Dec 11, 2010 16:46:33 GMT 1
Not loving the look of a 1kt front end on my LC, looks a bit unbalanced. What front end could I easily use fitting the following wish list: 110/17 tyre forks a bit chunkier than an lc but no bigger in diameter than about 40mm flat top yoke to weld risers on reasonably cheap I had an FZR250 3LN front end fitted to my 4L0 a while ago, 110/70 x 17" tyre fitted to 2.75 wide rim. Forks were 39mm dia, with 4pot calipers. It also had a flat top yoke that had risers welded on. OEB
lckwik
Post by lckwik on Dec 11, 2010 17:29:02 GMT 1
I had an FZR250 3LN front end fitted to my 4L0 a while ago, 110/70 x 17" tyre fitted to 2.75 wide rim. Forks were 39mm dia, with 4pot calipers. It also had a flat top yoke that had risers welded on. OEB [/quote] That is exactly the look I am after. The bandit stuff can always go on my spare RG500 frame
Post by leaky on Dec 12, 2010 12:32:30 GMT 1
Im using kr1s forks on my LC, twin disc, fat top yoke, rwu and 17 inch front wheel Sean - what rear are you going to use. As you know I'm KR1s both ends, but the 140/60/18 rear tyre is in short supply & I don't think I can get a 150 in the JMC. I fancy a 17" replacement, but the 5 spoke kwak ones are funny to match. Suggestions welcome. Aprilia RS250? I've seen these - cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290511289112&category=9888&_trksid=p5197.c0.m619 and they look very close. However, I think they might be a 5.5" back wheel so not much use in an old skool swingarm unless the complete transplant is done. I think they need adapting to fit the RGV swingers too...
Post by cb250g5 on Dec 13, 2010 0:36:42 GMT 1
Interesting - I'll do some digging into Aprilia wheels- the style looks close enough. Cheers
Post by seanrd on Dec 13, 2010 1:31:36 GMT 1
Hi Jason, Ive got a 3MA arm in the back and currently a 3 spoke belgarda brembo wheel. 17x3.00 But once a 3XV one comes up i might try that out. The fronts got a 3MA wheel in kr1s forks.
Post by watchhislegs on Dec 13, 2010 19:03:49 GMT 1
Have a look at Aprilia RS125 wheels or any of the 1990's Jap 125's. I'm sure a few of them have 140 rears. Mitos might be worth a look too.
Post by cb250g5 on Dec 14, 2010 0:23:14 GMT 1
Have a look at Aprilia RS125 wheels or any of the 1990's Jap 125's. I'm sure a few of them have 140 rears. Mitos might be worth a look too. I want to keep the style of the kwak 5 spoke ones though, or change both wheels I guess...
Post by seanrd on Dec 14, 2010 0:43:21 GMT 1
Only issue with the 125 wheels are that they are right hand chain. So the rear has to run in reverse
Post by seanrd on Dec 14, 2010 0:44:32 GMT 1
Honda NSR250MC18?? Was that a 17 inch rim?
Post by watchhislegs on Dec 14, 2010 1:59:10 GMT 1
You could use a 125 right hand chain wheel, just turn it round. Then turn the front round to match! You're going to have fun whichever way you go.
Post by trev1340 on Dec 14, 2010 12:05:29 GMT 1
I know its not a great deal of power but ar'nt the wheels designed to run one way only due to the shape /curve of the spokes like tyres otherwise all the stress is being forced in the wrong direction then you will have to turn the discs aswell depending on wether they are sided or not or you could start getting fractures where the spoke meets the rim but i am no expert just my veiw
Post by cb250g5 on Dec 14, 2010 19:20:44 GMT 1
I know its not a great deal of power.... I beg to differ
Post by trev1340 on Dec 15, 2010 17:02:09 GMT 1
you can beg to differ not being nasty or anything like that but can you explain why for me cheers
Post by cb250g5 on Dec 15, 2010 19:14:59 GMT 1
you can beg to differ not being nasty or anything like that but can you explain why for me cheers Cos my bike does have a great deal of power. Within reason.
Post by trev1340 on Dec 16, 2010 17:30:06 GMT 1
if its got a great deal of power that would make it worse surely ? would you put standard lc wheels in the wrong way round ?
