Post by Deleted on Nov 24, 2010 13:00:12 GMT 1
Can you run a tzr crank and con rod in a rd mk1 engine with a rd piston and barrel ?. I know the tzr little end bearing have a slightly bigger outside diameter but the inside diameter is the same as rd mk1 gudgeon pin. Would this make a difference to the port timing???.
Post by LC'Adam on Nov 24, 2010 22:59:32 GMT 1
Nah mate, won't even fit. Con rods are different lengths for a start Best crank to use in an rd bottom end is an rd crank ;D ;D ;D
